Results 1 to 7 of 7
    Long,medium or short cage for 11T-32T cassette?
    Hello, I did read the sticky, but I still can't figure out which one I need. I'm planning to buy SRAM derailleurs and shifters, but I need to know what kind of rear derailleur I need if the rear cassette has 11-32 (8 speed) teeth and front has 24-42 (3 rings).
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by eedijs View Post
    Long. Not 10-speed.
    mtbtires.com
    Long
    What do you mean by "not 10-speed"? Are you sure that I should get the long instead of medium? What's the difference?
    He means that a 10 speed derailleur is incompatible with 8 or 9 speed shifters, so make sure that you buy an 8 or 9 speed derailleur.
    Riding slowly since 1977.
    You have a tooth difference of 39 teeth. Capacity of a medium is 37. Should be a long. Medium would probably work if you were very careful with chain length but you would not be able to change your gearing.
    Thank you very much, I'll be getting the SRAM X4 then, which is a long cage. This is the first time I change derraileurs and shifters for this bike (5 years old), should be much better.
  1. 1x10 set up worth replacing Shadow+ XT Medium Cage R Derailleur with ZEE Short Cage?
    By PCTele in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-02-2013, 03:18 PM
  2. Zee short cage shodaw plus or xt medium cage shadow plus?
    By GVSS in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-08-2013, 04:19 PM
  3. Replies: 3
    Last Post: 05-22-2013, 01:59 PM
  4. Medium or Long Cage RD with 11-36 cassette & 26-38 crank on VPP bike
    By mmhsval in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-07-2013, 03:26 PM
  5. Replies: 3
    Last Post: 02-20-2012, 07:42 PM
