    Feb 2015
    Long cage with one chainring
    Hello. I just ordered an XT long cage 10sp rear derailleur because I wanted the little clutch gizmo. Now I've decided I'm going to switch my front triple 22/32/44 to a single 34T chainring, and proceeded to order stuff for that.
    So will the new long cage derailleur work fine with a single 34T chainring (and 11/36 cassette)?
    Reputation: 11053's Avatar
    It will work fine.
    However, long cage can be less than ideal for a 34/36 combo.
    A bit more chain + cage than you need, but it may be no big deal depending on your frame + trail conditions.
    Make sure you employ a narrow/wide front chainring.
    dadamamabooboo
    Reputation: bigchillcar's Avatar
    Aug 2014
    yeah, with a 11-36 and a single front ring, you need a rd with a capacity of only 25 teeth, which you could now manage with a small cage (rated capacity 25 teeth). i run a 2x drive 20/36 with a 11-36 rear and use a medium cage (rated 35 teeth for shimano). your long cage is rated to 43 teeth. if you're not familiar there's a formula to determine what capacity you need. definitely use a nw chainring as 11053 recommends.
    2011 Trek Mamba 29er 21", SRAM 10-sp X9, X9 type 2 RD, SRAM X7 20(oval)/36 & SRAM X9 2X FD, Shimano XT M771 11-36, M525 hub
    Feb 2013
    It will work fine. Had SLX long cage and 34 front ring for a while, no problems at all.
  1. long cage or short cage deraileur for 1x10
    By ToneyRiver in forum All Mountain
    Last Post: 03-17-2014, 02:21 PM
  2. Shimano Exage Long Cage vs. Acera Long Cage
    By jeffj in forum Vintage, Retro, Classic
    Last Post: 11-12-2013, 04:53 AM
  3. Need Help-Can I use X9 Long Cage Pulley/Spring Assembly for XO Rear Derailleur Cage?
    By red bank rider in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-10-2013, 09:58 AM
  4. Stay w/ long cage deraileur or switch to a med cage?
    By Tfrost in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-14-2011, 09:35 AM
  5. Short cage vs long cage-rear mech
    By Qcamel in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-23-2011, 02:55 PM
