Results 1 to 7 of 7
    Double-metric mtb man
    Reputation: Psycho Mike's Avatar
    New question here. Locktite for a ext BB?
    This may or may not have come up before....I recall something about it but couldn't find it again...
    I've got a Truvative Fire SX crankset with the external bearing bb. After about 500 km of riding, today it has decided to start getting loose on the hex that keeps the two halves together. I was riding a long distance and moderately hard, so it became a chronic problem on the ride today.
    I know I have heard of this before....but this is a first for me. Is it possible to just locktite the bloody thing, or am I going to run into troubles later if I do? If so, what color locktite would folks recommend?
    As if four times wasn't enough-> Psycho Mike's 2013 Ride to Conquer Cancer Page
    Moran? Let your opinion be free -> F88me
    thecentralscrutinizer
    Reputation: mopartodd's Avatar
    You're not going to hurt anything by using Locktite. Make sure you use the blue stuff though. Good luck.
    2015 Kona JTS
    2014 Scott Scale 710
    2014 Giant Anthem 27.5
    -> SickLines.com <-
    Reputation: mtb_biker's Avatar
    make sure its torqued correctly as well (that might fix your problem to begin with)
    Ride on
    I have been using blue Loctite on my Truvativ Stylo GXP crankset for some time now, and it definitely helps.
    It can do harm if it works its way into the bearings. I would think you shouldn't need it.
    Thanks for all the replies everyone.
    As the bike is still new, I ran it past the LBS where I bought it. The guys there are top notch and, as you said jmelani, thought locktite would be a bad idea as it could get into the bearings.
    They hauled out the torque wrench and got it back up to spec (which was a heck of a lot more than I could do out on the trail with the multi-tool) so hopefully it'll be good. If not, they figure something else is in the mix and they want the bike in to investigate. What can I say, the LBS is a gem and they look after me swell.
    Hopefully, I'll have nothing more to report on the issue
    Quote Originally Posted by jmelani
    I can't agree more. Especially if it finds its way into the bearing seals, your rubber seals are trashed. It will leak grease and let the contaminants come into the bearings. The bearing are compressed into the cup - if you pre-locktight the orphice, then the Locktihgt liquid will likely to find its way into the bearing. Not a good idea. I'd get some spacers that covers external bearing surface, stack them up, hammer the spacers to make sure the bearings sits level with the cup.
