Results 1 to 5 of 5
Thread: Left side drive
    My bike was -TWO- Wheels!
    Reputation: summitlt's Avatar
    Left side drive
    I thought it would be fun to put a left side drive on my Singlespeed. but the freewheel wont work going the wrong way.
    Are there freewheels anyway that can do this?
    I thought about modifing the one I have, but as I thought about it that would be impossible.
    Schwinn Moab DS3 Avids, Rhyno Lites, Speed Dials, Some other stuff.
    Homebrew flat black rigid commuter with a Shockster
    Gary Fisher BMX
    Get Avid Juicy 7's for 65% off!!!
    TC3
    TC3 is offline
    Reputation: TC3's Avatar
    Quote Originally Posted by summitlt
    Leave the rear hub alone, just learn how to ride backward
    From the land Down Under
    Reputation: Velophile's Avatar
    ACS make a LSD freewheel called a 'Southpaw'. You also need a LSD hub, the threads are also left-handed.
    I used a DK BMX hub, southpaw freewheel & Bullseye cranks for my LSD singlespeed at SSCW03. Worked well that way for a few months, then one of my pedals unscrewed & fell off.
    If you also use LSD capable BMX cranks this won't happen. SPD's don't work too well backwards either.
    Loose Nut Behind d' Wheel
    Reputation: Lucky's Avatar
    Quote Originally Posted by Velophile
    www.danscomp.com has LSD components. I gather the freestyle guys like the drivetrain on the left for grinds and such. Don't confuse a LSD rear hub for a flip-flop hub, though. A flip-flop hub is threaded for a freewheel on both sides and is used by folks who want to be able to use two different sized freewheels, but you turn the wheel around (flip-flop) to use it with a regular RSD.
    Kathy :^)
    Look where you want to go. This is as true in life as it is in mtbiking.
    I was thinking about all the threads then not being right, sounds like too much work...
    I think ill just leave it alone.
    One of my friends recently did it but didnt think of the freewheel being backwards that was pretty good.
    Gary Fisher BMX
  1. Shelving Rock Falls Big Loop info?
    By Adirondack Blues in forum New York - New Jersey
    Last Post: 07-11-2004, 12:35 PM
  2. Finding XC-Pro drive side crank arm?
    By GMF in forum Vintage, Retro, Classic
    Last Post: 07-10-2004, 07:26 AM
  3. Replies: 2
    Last Post: 04-04-2004, 09:58 AM
  4. Replies: 10
    Last Post: 02-25-2004, 11:59 AM
  5. Any reason a fixie couldn't be Left Hand Drive?
    By Fast Eddy in forum Singlespeed
    Last Post: 02-23-2004, 08:17 PM
