Results 1 to 8 of 8
    jzt
    jzt is offline
    Reputation: jzt's Avatar
    Largest recommended middle chainring for a 22T chainring
    I have a 22-32-bashguard setup currently. I go downhill a lot, so I want a bigger middle chainring for higher speed. I dont' want a big ring because I want to keep the bashguard (accomodates up to 38T).
    the question is: what is the largest recommended chainring that I can pair with my 22T? i'm thinking of 38T but could my front Deore derailleur handle such a big shift? I want to keep the 22T because I need it to get up the steep trails.
    Do It Yourself
    Reputation: Homebrew's Avatar
    14T is probably the biggest jump that you want to take. So that makes it 36T. You could try the 38T but I think you might have some trouble dropping the chain over the 22T. If you went up to a 24T, you could go with the 38T.
    Long Live Long Rides
    I ran a 16t jump ( 20-36) for years without any trouble, so based on that, I'd say your 22-38 will probably work. Note that I was using non-indexed shifters - I don't know if that makes it easier or not.
    I just got new (4 bolt) cranks which won't take a 20, so I may try 22-38 soon. If you try it, please post back here to let us know how well it works.
    Over the Hill
    Reputation: dstepper's Avatar
    20 tooth 4 arm
    http://www.boonerings.com/cr/orderformchainring.html
    It is slightly squared to fit 4 bolt pattern.
    Any one here using one?
    Chilling out
    Reputation: bear's Avatar
    Depends a bit on the front-d cage design, how much range it has.
    I've a current XT front-d, and running 22-34, and it's fine. 22-36 would probably work too, based upon the clearance that I can see, but more than that could be a problem.
    Reputation: MikeDee's Avatar
    Quote Originally Posted by dstepper
    What do you mean by squared (i.e. the ring ain't round)?
    Reputation: logbiter's Avatar
    I agree, especially for an indexed shifter. it'll also depend on what derailleur you're running.
    You can give it a shot, but it'll probably be finicky.
    I've run 24-36-48 with a mega9 XT, but it was a bit finicky, especially going up to the 48.
    It works much better with an older 8spd XT/XTR or 7/8spd suntour.
    yes, I'm loath to give up my 8spd ways and standard BCD cranks.
    Quote Originally Posted by Homebrew
    Over the Hill
    Correct
    To fit the bolt pattern, the 4 bolt 20 tooth ring is not perfectly round.
    I what to see one?
    I e-mailed Boone a month ago asking them to e-mail me a picture...they never responded. Boone makes quality stuff, but they are a small company.
  1. middle chainring positioning - is it important?
    By nampla in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-20-2005, 04:46 PM
  2. XT M760 crankset/ middle chainring
    By greenfin_demon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-18-2005, 09:30 AM
  3. slow shifting from middle to small chainring
    By gkd in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-10-2004, 07:48 AM
  4. Chain Drops From 3rd to middle chainring
    By rkj__ in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-02-2004, 11:10 PM
