• 01-05-2013
    Bill in Houston
    KMC MissingLink Removal Tips?
    Spent way too long removing a MissingLink today. What is the trick? I pushed it (opposite direction of the pull it normally sees), but it wouldn't slide inwards and release. I eventually bent it beyond recognition.
    Then, the ultimate insult was that another MissingLink in the chain fell apart just from the action of shaking the chain in a jar of spirits. :)
  • 01-05-2013
    rschroeder714
    You can buy a tool for it but I find putting some triflow on it and work it into it pretty well it comes apart much easier
  • 01-05-2013
    StolltheMusic
    The answer to your problem. Works wonders.
  • 01-05-2013
    StolltheMusic
    Technique: Squeeze in the middle of the link with your fingers while using the tool.
  • 01-05-2013
    Bill in Houston
    I was missing the part about squeezing the side plates together. That must be the trick. Thanks, guys!
  • 01-06-2013
    .40AET
    That is the first step. I've never needed the tool. If the chain is really dirty, then I might clean it with a solvent and a toothbrush first. Sometimes the dirt can keep the side plates from moving in.
  • 01-06-2013
    DennisF
    Buy the tool that StollTheMusic references. I did it by hand, but ended up with bloody fingers before I was done. This tool is 5-star quality as you would expect from Park.
    The tool is also helpful in reassembly to hold the chain ends together.
  • 01-06-2013
    tangaroo
    I just use a set of hobby needle nose pliers.
  • 01-06-2013
    Bill in Houston
    I was applying plenty of squeezing force with a ziptie and a pair of needlenose and my hands. Squeezing the side plates had to be the missing factor, or some dirt getting in the way of the side plates moving in. Thanks for all confirming that it's not as hard as it seemed. :)
  • 01-06-2013
    jhymel
    Learn to do it without the tool. If you have to repair a chain on the trail you won't have that tool. It's very easy to do. Squeeze the plates together in the center of the link and then slightly wiggle the chain on both sides of the link together. Yes it's messy but I can remove the link by hand in less than 10 seconds every time.
  • 01-06-2013
    SCR818
    This helpful for me, too. I'm upgrading my drive train this week and getting the missing link apart has always been a nightmare for me. Thanks for the tips! :thumbsup:
  • 01-06-2013
    Stormwalker
    It seems like an impossible struggle for me to get it apart with tension on the chain. However, remove the rear wheel, and I'll have it apart in seconds. So there's another trick.
