Results 1 to 11 of 11
    A REAL RIDER
    Reputation: Rearwheelslider's Avatar
    Kink in my chain
    My 2005 trek fuel ex7 has a kink in one of the chain links. It is noticeable only when spinning the crank backward. It will jump a tooth on the derailer. Also I believe this is the cause of the skipping problem that I am having when in fifth thru seventh gear hard. Tried oiling the chain but it still has a kinky chain link. What is the cause of this and do I need a new chain?
    Probably just a tight link and easy to repair...http://www.parktool.com/blog/repair-...ct-5-ct-6-ct-7
    If it is indeed a tight link which isn't flexing then all is well. If looking along the chain it is bending sidewards (ie the metal of the chain is twisted or damaged) then you'll need to remove that part of the chain and rejoin with a proper pin or joining link. You need to assess then if the chain is then too short for normal use. If the chain is old anyhow then you might consider replacement. Be aware you may have issues with a new chain meshing properly with the other drivetrain parts
    A REAL RIDER
    Thanks. I will try to fix it. The bike has low use and is on the original chain. I also think the chain is too long. Could this be an issue?
    Quote Originally Posted by Rearwheelslider View Post
    ...I also think the chain is too long. Could this be an issue?
    I wouldn't expect that to cause a "kink" in the chain.
    soak it in pb blaster
    A REAL RIDER
    Quote Originally Posted by gmcttr View Post
    No I know. I am asking if a long chain could be an issue in general because when I am in first gear(small front, small rear) the chain rubs the derailer.
    Reputation: shiggy's Avatar
    Dec 1998
    You should not use the small/small combo.
    Some suspension frames need "extra" chain.
    mtbtires.com
    Jul 2003
    A chain that's a tad long isn't likely the problem. It' not uncommon when in extreme gear combinations like the small/small or the big/big to get some chain rub on any bike, FS or Hardtail. As shiggy noted these are not really usable gear combinations as they can cause rapid chain wear and are hard on the cassette and chainrings as well.
    If you are only getting rub in the small/small combination and this is in the work stand it can also be quite normal on an FS bike. With the suspension un-sagged, i.e. you aren't on the bike, the rear suspension is fully extended. This puts a slight angle on the chain as the rear axle is lower than the bottom bracket and caused the chain to ride on the lower part of the front derailleur cage. When riding on the bike the rub will disappear. This occurs on many 4" and longer travel bikes. So check it and see. Even if this isn't the case it's not really an issue, that gear combination really shouldn't be used anyway. But it is likely that it has more to do with your suspension design than the chain being too long.
    Good Dirt
    Shift to big big combo any room left to shorten it???
    hay bud i have the tool! come over
  1. Chain kink on a Heckler
    By remsen in forum Santa Cruz
    Last Post: 05-14-2009, 08:13 AM
  2. Kink Liberty 09 *Or* Fit P1 05?
    By Gabriel47 in forum Urban/DJ/Park
    Last Post: 10-28-2008, 06:10 PM
  3. Kink Liberty OR Fit P1?
    By Gabriel47 in forum Bike and Frame discussion
    Last Post: 10-28-2008, 05:13 AM
  4. Kink Liberty OR Fit P1?
    By Gabriel47 in forum Beginner's Corner
    Last Post: 10-27-2008, 07:25 PM
  5. Kink Kikapu or 575?
    By pogie in forum Bike and Frame discussion
    Last Post: 10-28-2004, 01:48 PM
