Results 1 to 5 of 5
    Just got new Shimano LX Cranks... how do knwo what size BB
    OK, so i just picked up set of Shimano LX Hollow Tech M572 cranks. The bottom bracket that goes w/ it is the Shimano BB-ES51, i have seen them all over different web site, but they all have differnet sizes. How do you know what size is needed? What do you measure?
    Also.... anyone have a little "How To" on changing Cranks and Botton Bracket?
    Freshly Fujified
    Reputation: Call_me_Clyde's Avatar
    121mm
    I own two sets of the FC M572 cranks. They need a BB ES 51 with a 121 mm long shaft. This is becase of the depth the splines need to go into the crank arms on this particular model of cranks. The BB shell will be either 68mm or 73mm. You need to check your frame for that measurement. I got my BB ES 51's cheap via Performance Bike. Right now the web site doesn't specify what length they have in stock. It just says 73mm.
    Bob
    'If Wal-Mart sold parachutes, who would jump?' Frank Havnoonian (quoting his father) Drexel Hill Cyclery
    thanks alot...
    Reputation: pspycho's Avatar
    Aug 2005
    I bought mine a few weeks ago. You do need the ES-51 BB from Shimano. The size depends on your frame. If you have a 68 BB Shell you'll need the 68 x 121. If you have a 73mm BB Shell, you'll need the 73 x 126. Good luck!
    2015 Specialized FATBOY EC70 Seatpost & Bars SRAM X7/Wolf 42T 1x10
    2016 Specialized DIVERGE Expert X1 SRAM 1x11 Force
    Freshly Fujified
    My bad
    Quote Originally Posted by pspycho
    You definitely need a 126mm if you have a 73mm BB shell.
