    Jagwire Ripcord DIY Derailleur kit - question.
    Just picked up a kit for my build and had a few questions about the small parts/accessories.
    Since I will be running full length housing, I will not be using the liner at all.
    I assumed that the kit is enough to do both front and rear derailleur, but the accessory bag only came with (1) end cap/ferrule. Wouldn't I need (3) end caps/ferrule to complete the housing? (both shifters and at the rear derailleur).
    Not sure if I'm missing something or not.
    ...In the meantime.
    Reputation: EvilBkr's Avatar
    Mar 2006
    Quote Originally Posted by anthonylokrn View Post
    I just looked at the spare Ripcord kit I have and it has 8 endcap/ferrules. One without the teflon nose and seven with. So if I read your question correctly you are definitely missing some parts.
    Quote Originally Posted by EvilBkr View Post
    I do have the (7) nose ferrules but didn't think I would be using them since I'm not using the liner. So both shifters will use the nose ferrules and the rear derailleur will be the alloy ferrule WITHOUT the nose?
    -_- Nevermind. Didn't notice that there were end caps pre-installed at the ends of the housing.
  1. Jagwire Ripcord going full length from shifter to derailleur
    By arcticrobot in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-05-2011, 07:18 PM
  2. Jagwire Ripcord and BB7
    By Pelly_NH in forum Brake Time
    Last Post: 07-07-2010, 03:12 PM
  3. Replies: 6
    Last Post: 04-24-2010, 01:07 PM
  4. Replies: 2
    Last Post: 04-21-2010, 07:18 PM
  5. Jagwire Ripcord derailleur cable install question
    By Mondoman1 in forum Brake Time
    Last Post: 07-15-2008, 08:19 PM
