Results 1 to 2 of 2
    Reputation: JerB's Avatar
    Isopropyl alcohol as chain cleaner?
    Hi Guys,
    I dont usually apply any degreasers to my chain unless they are gunked up good and need a good cleaning. I always clean my chain with a small brush and re apply lube and run through a rag.
    When I do use degreaser I use the ecotech stuff and let it sit on my chain for a few minutes and then run it through a rag until no more crud comes off. After that I spray warm water on the chain to make sure I have the degreaser off before reapplying new lube.
    What I want to know is instead of using the ecotech stuff can I just use 99% Isopropyl alcohol as a degreaser? I assume as it would evaporate fast I would have to do the whole rinsing of the cahin before applying new lube.
    Thanks for any tips guys
    One of these days I will get a chain that has removable links, Im sure it would make cleaning a chain easier
    Jeremy
    Feb 2013
    1) Use biodegradable mineral spirits; put spirits and chain in a 2 liter bottle; shake; save and reuse it.
    2) Use alcohol to rinse off the mineral spirits.
    3) Lightly lube chain.
  1. How do YOU clean your bike chain without a chain cleaner device???
    By stonemxfan369 in forum General Discussion
    Last Post: 11-24-2014, 06:37 PM
  2. Replies: 0
    Last Post: 06-15-2013, 02:46 PM
  3. Alcohol hand gel as disc rotor cleaner?
    By Muscleflex in forum Brake Time
    Last Post: 01-04-2013, 04:35 PM
  4. spray bottle for isopropyl alcohol?
    By mack_turtle in forum Tooltime
    Last Post: 09-20-2012, 10:32 AM
  5. Replies: 4
    Last Post: 04-12-2011, 09:42 AM
