Results 1 to 6 of 6
    Reputation: SManZ's Avatar
    Jun 2013
    ISCG 05 Chain Catcher?
    I'm having a hard time finding a ISCG 05 mounted chain catcher for my 2013 Stumpjumper FSR Carbon. Dropped a chain today, and it happens rarely, but I want to make sure it doesn't get jammed against the frame again.
    It seems like my options are;
    Get something like the Blackspire Stinger and remove the pulley.
    Get a ISCG 05 mounted 2x chain guide (like in this thread)and do away with the one that came on the bike.
    Thoughts and recommendations are appreciated!
    I have a black belt in MS Paint.
    2013 Santa Cruz Bronson Carbon
    2013 StumpJumper FSR Comp Carbon 29er
    meow meow
    Reputation: b-kul's Avatar
    a regular seat tube mounted one wont work?
    Reputation: Shalom's Avatar
    Nov 2008
    1) Have you got a clutch RD? If so, is the clutch activated?
    2) Where is the chain derailling? Top? Bottom?
    3) Is your chain length good?
    4) Are you using 2 rings? ie do you still have your FD on?
    Jun 2013
    No, and those are all I could find. On the carbon StumpJumper FSR the seat tube is not round and the diameter increases as you get closer to the bottom bracket.
    Quote Originally Posted by b-kul View Post
    Jun 2013
    1) Yes, Shimano XT and the clutch is activated
    2) Bottom drop. Today was the first time it happened in the 300mi I've run this bike, so its not a common occurence. Just looking for something to prevent the frame damage if it happens again.
    3)Chain length might be a smidge long. The bike came stock with a 36/22. I changed out the big ring to a 34/22.
    4) Yes & yes.
    The chain drop happened while shifting to the small ring going uphill. I'm going to adjust the front derailleur tonight. It does need a little adjustment anyway. Still, I'd like to find something that will serve as a chain catcher.
    Quote Originally Posted by Shalom View Post
    Nov 2008
    Then I would suggest shortening the chain a touch (might help increase tension through combination of clutch and dangler).
    If that does not work, then one of the 2x guides you linked to above. The e13 one is good (from experience), MRP is very similar, I have heard good things about Blackspire. Also consider Gamut (P20 or P30 dual ring setups).
  1. Chain Catcher without any spacers on the BB?
    By jazzanova in forum 29er Components
    Last Post: 04-19-2013, 11:13 AM
  2. Chain Catcher for Jet 9 RDO
    By WoodstockMTB in forum Niner Bikes
    Last Post: 03-22-2013, 07:07 AM
  3. Chain catcher for Superfly
    By Robsibis in forum Trek
    Last Post: 08-06-2012, 11:05 AM
  4. Replies: 4
    Last Post: 03-02-2012, 09:08 PM
  5. Chain catcher for xo 3x10
    By jazzanova in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-14-2011, 07:57 PM
