Results 1 to 2 of 2
    Intense Spider & Race Face Deus Cranks Spacing?
    What spacing for chain line did you use or what will work the best. Thanks
    Chrome Toaster
    Reputation: Hecubus's Avatar
    Quote Originally Posted by promtber
    I have the XTR cranks on mine which have a 50mm chain line only. If you're using the race face cranks I recommend going with the longest chainline option of 50mm rather than the default 49mm. The reason for this is the Spiders support strut in the rear triangle leaves very little clearance for the front derrailleur in the granny gear. You want to get the derailleur as far away as possible.
