Results 1 to 2 of 2
    Minor Threat
    Integrated BB bearing replacement
    I have read previously that the XTR ad RF bearings are interchangabe. Are thay both propriatary or is it something I can get at a bearing store off the shelf.
    Also, anyone know when the FSA cranks are coming out. I saw a set on SCOTT bikes web site.
    A Midwesterner in Europe
    Sep 2004
    The Race Face Bearings will work with the Shimano Cranks and I would recommend it over the Shimano ones. If you do use the XTR BB cups make sure that the seal is present on the non-drive side crank arm. That seal has been a cause of most of the failures on that non-drive side cup.
    The only thing you'll need to check is what spacer combination you need to use for a 68mm shell or a 73mm shell. You can even use a Dura-Ace Cup if you want, but I wouldn't, the threads are shorter to lighten them over the XTR cups.
    And I'm not sure about the FSA one, TruVativ has one for road bikes out.
  1. BB Replacement
    By dag560 in forum Beginner's Corner
    Last Post: 09-02-2004, 09:37 PM
  2. Lightweight, durable ISIS BB?
    By 1speed_Mike in forum Weight Weenies
    Last Post: 09-01-2004, 01:07 PM
  3. Chainline ISIS BB Replacement
    By GP-TJ in forum Singlespeed
    Last Post: 07-23-2004, 07:06 AM
  4. '01 Intense M1 pivot bearing replacement.
    By Dartman in forum Downhill - Freeride
    Last Post: 06-05-2004, 06:33 PM
  5. bushnell ebb/external bb bearing question
    By sslos in forum Singlespeed
    Last Post: 03-19-2004, 05:52 PM
