Results 1 to 2 of 2
    Nor­wegr
    Reputation: Vegard's Avatar
    Installing XX1 crank on Cannondale Scalpel '12 - semi urgent help required
    Finally got around to installing my XX1 crank, or attempt to do so atleast when I ran into a problem on my '12 Scalpel.
    From reading the manual for the frame, the manual for the xx1 crank and measuring the bb myself it is a 73mm bb.
    However, when I put the crankset on with no shims as the xx1 manual stated, the chainring grinds against the chainstay. I used the flat faced BB shields.
    Should I put a shim on even though the manual says it isn't required?
    For a 68mm bb the manual states that 1 shim should be used on each side.
    Thank you for any help!
    Take a look at the doc just posted here. Might help determine what's wrong.
    XX1 crank chainline (found the answer :))
  1. Semi-Newb Looking for Scalpel/Jekyll Advice
    By n_maher in forum Cannondale
    Last Post: 11-19-2012, 08:41 PM
  2. Replies: 6
    Last Post: 08-15-2012, 09:11 AM
  3. urgent crank help!!
    By moneycash in forum Yeti
    Last Post: 11-10-2011, 12:16 PM
  4. Replies: 2
    Last Post: 05-17-2011, 05:18 PM
  5. Replies: 9
    Last Post: 04-17-2011, 08:57 AM
