Results 1 to 12 of 12
    Reputation: nathasm's Avatar
    Installing a 20T chainring
    So I just put on a new 20T chainring which I downgraded from a 22 on my XT crankset with a 32 in back. Now, when I pedal in the granny, I'm getting skipping. It looks like the teeth are not matching up on the chain. Is the ratio off now? Is there a way to fix this problem?
    .nathan.
    Reputation: MikeDee's Avatar
    Quote Originally Posted by nathasm
    .nathan.
    Did you use a new chain?
    New everything
    Quote Originally Posted by MikeDee
    Yep, new chainrings, new cassette, and new chain.
    .nathan.
    Reputation: logbiter's Avatar
    first make sure you got the chainring orientation right.
    I suspect that the chain might be a bit long, check out the tension when in the granny.
    .nathan.
    Quote Originally Posted by logbiter
    Also it might make a difference which side of the chainring faces in towards the bike.
    members only
    Reputation: ET_SoCal's Avatar
    Jul 2003
    Look closely at the inside (nuts) - Does the chain rub ever so slightly on them? Rising up just a barley noticeable amount?
    Sep 2004
    .nathan.
    Where did you get a 20T chainring for an XT Crankset? I thought 22T was the smallest for a 64 BCD.
    members only
    Jul 2003
    Quote Originally Posted by spinjocky
    ... 22T was the smallest for a 64 BCD.
    I believe this is true, (unless there's some custom/special set-up outthere somewhere).
    Compact drives (58 BCD) are the only one's that can run a 20T small. (Or is it an 56 ?)
    ballbuster
    Reputation: pimpbot's Avatar
    second that
    Where did you find a 64 bcd 20t chainring? I have a 22 on my bike and it seems that the chain is right on top of the chainring bolts. I use a 34t big cog in back to get the same thing you are after. A crazy low granny gear.
    Boone
    It's a boone titanium chainring. I got the 20 and a 32 made for my XT crankset.
    .nathan.
    Reputation: lebikerboy's Avatar
    Jan 2005
    Talked to the boys at Cycle Dynamics today re your 20 tooth granny gear on a 64 BCD crank. They don't make 'em cause they don't always work.
    .nathan.
    members only
    Jul 2003
    Quote Originally Posted by pimpbot
    ... chain is right on top of the chainring bolts.... crazy low granny gear.
    With 9-sp (34 rear cassette) I've seen problems getting a 20T front to work well.
    8-sp (32 rear) with the right nut-bolt combinations can work w/ 20T front.
    Then again - I haven't seen a 9-sp compact drivetrain. There might be some special made somewhere, but none that I've ever heard of. [Edit] I takes this back, There's plenty of 9-sp compact, I was thinking purley Shimano [/Edit]
    ... I got the 20 and a 32 made for my XT crankset...
    I think you mean; "It's made for a compact crankset". I doubt they made one ring just for you, unless you’re a sponsored racer.
    Then again a sponsored racer rarely goes in the small ring, so ....
  1. 20t 4 arm chainring?
    By jakeplazma in forum Weight Weenies
    Last Post: 03-13-2005, 02:04 AM
  2. Replies: 5
    Last Post: 01-14-2005, 07:52 PM
  3. MOTD: Make sure your chainring bolts are tight
    By dubjay in forum Singlespeed
    Last Post: 12-13-2004, 05:24 PM
  4. 20T 5-bolt compact chainring?
    By tmaybee in forum Weight Weenies
    Last Post: 09-18-2004, 03:15 PM
  5. 20t chainring on Next LP crankset?
    By precar in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-23-2004, 05:43 PM
