Results 1 to 9 of 9
    Reputation: sfgiantsfan's Avatar
    Dec 2010
    I need a couple more granny gears
    Just switched to a 1x10 from a 2x10(new bike). How can I get the other geas back. Can I go smaller than a 32 teeth front chainring? Should I go for a 1x11 or should I just spend the cash and get a new FD and go back to a 2x10.
    I'm sick of all the Irish stereotypes, as soon as I finish this beer I"m punching someone
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by sfgiantsfan View Post
    If you need the lower gearing, go back to double chainrings. No brainer.
    mtbtires.com
    Dec 2010
    It's a cash flow thing, summertime etc. I have a couple trips and didn't want to spend the cash on a new FD, shifters etc
    Dec 1998
    Then why did you go 1x in the first place or ask this question? (No need to answer)
    mtbtires.com
    You can stick an 11-36 cassette on your backside.
    Your crankset will dictate how small a front ring you can run.
    As for trips and 1x10,
    I can see having 1x10 on a trip as it does simplify things. There's just less to go wrong. However, unless you know trip routes well, the diverse gearing of a 2x10 could be the better call. You could always have 2-3 front rings with you to adjust depending on the route, but that's a lot of work too.
    Lead by my Lefty............... right down the trail, no brakes.
    Dec 2010
    Quote Originally Posted by shiggy View Post
    I got a new bike and it is a 1x10. I was just wondering if it was possible to go smaller front ring or bigger cassette instead of spending a bunch of money going 2x10
    Dec 1998
    Without knowing what crank and cassette you currently have there is no answer for your question.
    mtbtires.com
    Dec 2010
    Thanks, that's the kind of info I'm looking for. Ill check when I can
    meow meow
    Reputation: b-kul's Avatar
    if you have a 104 bcd crank race face and wtc make 30t rings that work with no mods. if it is spiderless you can get down to 28t (or maybe lower?). and of course if you dont have it an 11-36t cassette will help.
  1. Tie up your granny
    By Crash&bern in forum Eastern Canada
    Last Post: 10-19-2012, 07:50 PM
  2. No more Granny Gears.
    By zdiggler in forum Beginner's Corner
    Last Post: 06-01-2012, 05:20 PM
  3. Comparing Granny Gears
    By Billinsd in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-27-2012, 11:03 AM
  4. 20T Granny
    By S_Trek in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-26-2011, 11:24 AM
  5. Couple Questions (helmet, and gears related)
    By naiku in forum Beginner's Corner
    Last Post: 04-14-2011, 06:34 AM
