Results 1 to 3 of 3
    2:1 is offline
    Reputation: 2:1's Avatar
    I need 2x9 180mm, what should I do?
    Adapt XT or XTR to a 29t? Does anyone make a 29t with the correct BCD?
    Use some old stuff?
    Something new I don't know about?
    Please advise!
    Reputation: Nater's Avatar
    I'm doing something similar...
    this year on my 29er hardtail. As far as I know, 29 tooth rings aren't easily available without going custom or finding one of the older Ritchey setups. I got and old LX square taper crankset (with the cassette style chainrings) off of eBay that I had a 5 arm 94/58mm spider for. I'll be running 30/42 tooth rings and an 12-34 tooth cassette. I think the square taper cranks might be better for this application since you can fine tune chainline with different spindle lengths...the newer splined cranks don't usually offer more than 2 spindle lengths and the shorter one is usually a bit too long for a double chainring set up.
    Reputation: shiggy's Avatar
    Dec 1998
    I used a 2x7 for several years.
    The front was 45/28 on a 110/74 BCD crank. Used a 28t inner ring and the 45t set in the middle position.
    Used a 12-34 7 speed FW.
    mtbtires.com
