Results 1 to 3 of 3
    I am switching out the bashguard on a SLX double crank
    The BBG bash is much lighter (practicality) and a bit more trick looking (vanity ). However, I am guessing that the BBG is a bit narrower as compared to the original SLX guard. Where can I source some spacers to cover the extra bolt length, or would it be better to go with some new shorter bolts?
    Thanks in advance for the help.
    B
    Reputation: boomn's Avatar
    normal chainring bolts for 3 rings setups work properly with the BBG. The SLX bolts are special extended versions IIRC because of how thick the bash is.
