Results 1 to 9 of 9
    Bicyclochondriac.
    Hydraulic drivetrain?
    Anyone know if the idea of a hydraulic drivetrain (as opposed to chain-driven) has been explored much for bikes?
    bi-winning
    Reputation: rkj__'s Avatar
    I don't think it has been done, AFAIK.
    Could you give me an example of a vehicle that has a hydraulic drivetrain?
    Bicyclochondriac.
    Quote Originally Posted by rkj__
    I think some tractors use it. I've driven a Bobcat, and it used hydraulics for the drivetrain, and my uncle had a tractor that did. I don't know how it works (think I'll look it up).
    Bicyclochondriac.
    Just answered my own question...
    Quote Originally Posted by kapusta
    Just answered my own question, a least partially....
    http://www.powerengine.com/aitx000liquidbik.htm
    Person
    A friend made one for a college project. Didn't really work, but it looked cool.
    Hydraulic Transmissions will have a maz efficiency around 80% or lower.
    Well maintained bike will be 95% efficiecy.
    Ouch!
    surfer w/out waves
    Reputation: havnmonkey's Avatar
    I was thinking hydraulic shifter/der combo...but it looks like Shimano and Campy have put there money in the electronic boat.
    "Listen, strange women lyin' in ponds distributin' swords is no basis for a system of government!..." -- Dennis the Peasant
    Person
    Quote Originally Posted by havnmonkey
    Safe Products made a hydraulic conversion for Shimano in the mid-90's.
    Loaders, many dozers, bobcats, many modern tractors.
    However they have them for a purpose, in that they can be controlled to provide varying pressure on the wheels under varying loads at varying speeds, with a "torque converter", rather having to slip a clutch or continually change gears to get enough revs to be in the engine's power band.
    For instance if you drive a loader on the flat with the engine at constant speed and constant throttle, then start up a hill, the engine maintains speed, but the loader slows down more with steepness. It has not actually changed gears. Same goes if you start pushing a load.
    They are also set up very nicely to "shuttle" from forward to reverse without a clutch. Not really much use on a bike....unless you are a trials freak! <G>
    They are not efficient. They are heavy. Some sort of automatic gearing on a bike would be nice, but these are not the way to go.
    The other hydraulic alternative (and this is what, IMO, is used on the bike that a link in this thread leads to) is a direct drive system: "positive displacement" I think they are called. That is where a pump drives a motor, and both completely block the passage of fluid unless they are moving, as would a piston system. These are more efficient, but still lose a lot to friction, compared to a chain or even gear drive. They have to, in order to be sealed so tightly. You simply cannot turn a good hydraulic motor by hand. They also need very high pressures (heavy components) or high fluid flow (loss due to friction in pipes etc)
    I remember seeing an attempt at auto-gearing on a bike, which actually changed the length of the spokes on the rear wheel....no.... ....it changed the length of the "spokes" on the chainring as the pressure on the pedal changed. I heard no more about it
    Nick
