Will there be any problems matching those 2 parts together? I'm aware that the Special 32 is a 1 ring chain guide so I'll remove the small chain ring. I know that the patterns fit (4 bolt, 104mm BCD) but was wondering if I might encounter some compatibility issues. I know that some combinations of CG and crank require to grind off the small ring tabs, will this be the case here? Any other problems I'm not expecting?
Thx for the info
P.S. The frame is a 2005 Norco Six VPS by the way.
