Results 1 to 6 of 6
    Reputation: !bike's Avatar
    How tight is 4 - 6 in. lbs (Shimano XT/XTR Hollowtech bearing preload)
    I own a torque wrench, but exactly how tight is the appropriate pressure
    on a Hollowtech cap? Docs say 0.4-0.7 Nm (4-6 in lbs).
    I assume this means just enough preload until the end play is gone and
    the o-ring seals against the bearing plates? Kinda like old unsealed bearings
    of old? Should one, tighten, spin, and tighten again?
    My torque wrench has sort of a low end of 10 Nm. Need to find torque scredriver.
    -r
    Old man on a bike
    It's pretty much finger tight, I don't use a tool at all.
    suum quique
    Vaginatarian
    I dont think your torque wrench will fit the plastic nut, Park tools has a external BB wrench that has a thumbwheel nut tightener on one end. I tap the other side of the crank with a rubber mallet first, then tighten the nut .
    Chrome Toaster
    Reputation: Hecubus's Avatar
    Very low, its barely finger tight. Use the plastic knob and hand tighten them until they are firm and snug. Its pretty difficult to overtighten them by hand.
    A wheelist
    Reputation: Mike T.'s Avatar
    It's one pound of pressure on the end of a 4-6" wrench. In other words - not much.
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilders with information and motivation.
    Quote Originally Posted by Mike T.
    Now that is something I can do! I had been try to sort of a click (it was the pedals
    being loose ), so I have been playing with the BB and have no sense
    of how tight this should be except that it is bearings. Now where is my spring scale ...
    Thnx all.
    -r
