Results 1 to 2 of 2
    May 2005
    how to replace cable on XTR SIS w/ disks HELP!
    I need to replace the rear shifter cabel on an 03 XTR with the intergrated (SIS) break/shifter. I can't figure out how to get the cable out??? I removed all the lil screws from the grey plastic cover but it won't come off. I am afrid it will break if I try to pry it off. Can any one tell me how to get the cable out..
    May 2005
    Got it. Thanks!
    I found a thread in this forum that covered the topic..
    You only need to remove the cover with the XTR logo on it. It has only 1 screw holding it in front. Once the screw is out you need to slide the cover out while pulling it outwards and down at the same time. Its got a plastic clip system to keep it from falling off if you loose the screw. Its very easy to take off but a pain the first time because you can't tell what direction it has to come out in.
  1. help! replace cable on xtr dual control shift levers?
    By elsaltamontes in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-29-2014, 07:28 AM
  2. 2004 Burner and XTR shift cable routing
    By Greyeye in forum Turner
    Last Post: 04-04-2005, 10:09 PM
  3. Replies: 6
    Last Post: 01-29-2005, 06:38 PM
  4. XTR disks and azonic tires?
    By Gramatica in forum Downhill - Freeride
    Last Post: 08-26-2004, 02:49 PM
  5. XTR shift pod quirk : need cable tension?
    By holden in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-22-2004, 11:31 PM
