Results 1 to 7 of 7
    Reputation: scottay's Avatar
    how to remove x type RF crank arm?
    Any help? trying to pull the RH crank arm from RF x type . thnaks, scott
    http://forums.mtbr.com/showthread.php?t=136309
    8mm crank arm bolt could be a pain to loosen if the guy assembled used locktight...
    thanks,
    but i have the bolts out, need to know how to pull the arm.....
    Au'Right!
    It's self extracting
    Leave the dust cap on (always make sure it's snug first though with a 10mm, and it's REVERSE thread, pay close attention to the writing on the dust cap) Then just loosen the 8mm. The 8mm will bottom out on the "dust cap" and pull the arm off as you turn the 8mm. So put the bolts and dust cap back in and start over. Hope this helps.
    Problem: "Bike has trouble going up steep hills."
    Fix: Recommend pressing harder on the pedals.
    Reputation: in the flesh?'s Avatar
    so reinstall the bolts and loosen the bigger one a bit. then unscrew the smaller oneand it will push up against the bigger one pushing the cranks apart.
    Your bike is incorrigible
    Reputation: Guyechka's Avatar
    It's going to take a long handled allen, because the x-types fit so snug. I use a piece of pvc pipe on the end of my allen set to give me some leverage.
    The 8mm bolt is going to push against the dust cap to pull off the crank. You have to be sure you have that dust cap threaded far enough down that it will stay put as you crank on the 8mm bolt. If it isn't threaded far enough, you could strip it. There shouldn't be that much wiggle room between the 8mm and the dust cap when you begin to extract.
    Thanks, thats what i needed. its on really tite tho, afraid i may round out the 8mm allen.
