Results 1 to 6 of 6
    how precise does the hanger need to be
    mines bent a touch, you can see the derailure is not in line perfectly. I've bent them back before with a large adjustable wrench, but how precise does it need to be for 9speed. I used to do this on 8 speed and "close" was good enough. just wondering if I will be hitting my head against a wall without having precision measuring instruments
    I remove the der. and hold a long straight edge flat against the hanger (using a 36" length of small, angled aluminum from lowes or hd). It's easy to get within 1/16". Hold the straight edge with one hand and measure the distance to the rim. Rotate the st. edge to find the lowest point and then tweak. Make sure the qr is tight, and the wheel needs to be true.
    Quote Originally Posted by Dichotomous View Post
    I have bent RD back on 9 speeds with sucess....If it shifts fine after you bend it back all is good...
    If not then get a new hanger....
    I have done it on the bike becareful.....of on a anvil with a hammer...probably better.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    If it is an aluminum hanger, get a spare anyway. Aluminum does not like being bent. It gets weaker and fails completely after a few times.
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    Jul 2003
    As little as 3 to 5mm out can make a difference depending on the orientation of the bend. Vertical alignment is the most critical, but horizontal alignment can can cause problems if severe enough.
    If you can actually see that the derailluer/hanger is out of alignment then it's certainly enough to give you problems. But by the same token, I've seen many hangers that didn't look bad, that were out enough to cause shifting problems with 9 speed and above drive trains. So using some sort of visual aide or an actual hanger alignment tool is usually needed.
    Good Dirt
    Nov 2008
    It has to be good enough for the shifting to be crisp and smooth. Folks make like there's a need for super precision, but if you have good eyes and hands you can get it good enough freehand. Ultimately, if you don't have a problem, than not being perfect doesn't matter.
    An easier way for a freehand bend is to stick a 6mm hex key through the upper pivot bolt, and use it as a bending lever.
    If you want better accuracy remove the RD, and use the adjustable as you have, being careful not to ding the flat area where the pivot bolt mates. You can then check by laying a straight edge against the flat, extending it to the rim and measuring with a ruler or using your thumb as a gauge. Do this at three points around the rim, matching the distance to prove that the face is on plane with the wheel.
    fb
    www.chain-L.com
    The key to solving any problem is to understand and address the underlying cause.
  1. Spoke length question, precise and rounded???
    By willymcd in forum Wheels and Tires
    Last Post: 04-05-2010, 09:03 PM
  2. What's more precise & quick shifting -SRAM XO Trigger or m970 XTR?
    By awai04 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-23-2009, 10:14 AM
  3. Dirt Labs Fast and Precise
    By MCtigre in forum Shocks and Suspension
    Last Post: 02-01-2009, 10:57 PM
  4. Getting a precise color match
    By uphiller in forum Frame Building
    Last Post: 12-30-2007, 08:10 AM
  5. Precise steering
    By cowdog in forum Shocks and Suspension
    Last Post: 06-06-2005, 08:51 AM
