Results 1 to 19 of 19
    May 2013
    How to install Shimano Hollowtech II to PF30
    I'd like to know the best way to install my shimano hollowtech II crank set to my salsa spearfish which uses a pf30 bottom bracket standard.
    Mar 2013
    if you have a 68mm shell and the cranks take the english threaded bottom bracket you can use this: Universal Cycles -- FSA PF30 to 68mm Threaded Adaptor
    or this for the wider shell: Universal Cycles -- Sram PF30 to English Thread Adapter
    I havent used either. But my cannondale did have a factory BB30 to english threaded adapter installed similar to the FSA that I posted.
    The simplest solution is often the best...
    Universal Cycles -- Wheels Manufacturing BB/PF30 to 24mm Adaptors
    May 2013
    Quote Originally Posted by the mayor View Post
    Thanks I was looking at that but I couldn't find any reviews. Anyone have any feedback on this one since it looks like it will require the least ammount of work to install since it looks like I won't have to remove the PF30 bottom bracket to get it to work.
    May 2013
    Thanks the second one looks interesting. I'll have to look into it.
    Quote Originally Posted by Lemonaid View Post
    How much of a review can you give a plastic spacer?
    I use them. They work...
    The more expensive PF30 to Regular BB sleeves will require you to buy a new bottom bracket...and the WILL creak...and are a PITA to remove.
    May 2013
    lol ok sounds good to me. I found them on amazone for about $21
    Mar 2013
    Mine NEVER creaked. Loctite makes a retaining compound that is supposed to be used with it.. same compound I use with the BB30 bearings, which also prevent any creaking.
    Oct 2010
    Thinking of moving to a Shimano on my Niner PF30.
    Can't really tell with this, but are the bearing in this adapter negating the need for the Shimano cups? It says to tap them into the bearing in the BB shell....there are no bearings in a PF30 shell....so I'm a bit confused. Thanks
    Mar 2013
    Quote Originally Posted by WoodstockMTB View Post
    Wheels Manufacturing Universal BB30/PF30 To Shimano Adapter
    "Simply tap the adapters into the 6806 bearing in the BB shell or cups, then install the cranks using the included spacers to adjust chainline, or to take up any side-to-side movement in the crank."
    If there arent any bearings in a PF30 shell, where are the bearings?
    Plays with tools
    Reputation: customfab's Avatar
    Praxis makes an adapter that appears to be really well made. I've been looking for an exscuse to use one in a customer bike. All of my frames have threaded BB's and ALWAYS will.
    Feb 2006
    Quote Originally Posted by customfab View Post
    Your choices might diminish in the future. I too don't like threadless BBs, but I wanted a new Ventana, so now I have one.
    I am using the Praxis with an XT 770 crank and so far so good. The bad news is that it has only been installed since late April. The good news is that I ride in very, very wet conditions and it's holding-up.
    We'll see how long it lasts.
    Sweet merciful crap.
    If 2 plastic spacers confuse you...I can't help.
    Quote Originally Posted by Pisgah View Post
    Good to know your Praxis is holding up. I have one on the shelf....looks very well made. I'm going to use it IF my BB30 bearings start eating themselves.
    Can you use a Shimano thread in b/b with it? Or do you have to use one of Praxis?
    ( I haven't even looked at that...but reading this thread made me wonder)
    I have had great luck with the Wheels MFG spacers on my Cdale road bike and mtb....and have had no problems with the BB30 systems.....but as soon as I do, the Praxis is going in.
    Plays with tools
    Glad your Praxis conversion is holding up well.
    I build my own frames so I'm in complete control of what BB shell I use.
    Reputation: Nater's Avatar
    Can you use a Shimano thread in b/b with it? Or do you have to use one of Praxis? ( I haven't even looked at that...but reading this thread made me wonder)
    If I'm not mistaken, the Praxis unit is a BB...not an adapter. It's got it's own bearings.
    Feb 2006
    Quote Originally Posted by Nater View Post
    Correct. I installed it without spacers and slid the crank spindle through. Just remember to use the special loctite for bearings (it's listed in the instructions). I let the bond cure for about three days before use.
    Oct 2010
    Oh please, Mr. the Mayor, find in your heart one more shred of tolerance for the ignorant and help a poor lad!
    I love genius D-Bags on interweb chat rooms. Such a commanding presence!
    Feb 2006
    Correction and Update: I own a Parlee BB adaptor. It's basically toast at this point. I installed it at the beginning of May - 2013. So it lasted 4 months. I ride in very wet and muddy conditions. However, all (and I mean all) other threaded BBs I have used lasted about a year.
    At least I can replace bearings without removing cups. So far no squeaking.
  1. Hollowtech II Crank install question
    By Mr5150 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-27-2013, 06:18 PM
  2. PF30 BB Install in Carbon BB Shell?
    By G-Choro in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-21-2013, 07:12 PM
  3. PF30 bottom bracket install on carbon frame question
    By brightsky in forum Niner Bikes
    Last Post: 03-11-2013, 01:13 PM
  4. PF30 Install Options
    By Alexgonzalezmi in forum Frame Building
    Last Post: 06-22-2012, 02:30 PM
  5. Shimano Hollowtech II. Help
    By justlearning in forum General Discussion
    Last Post: 03-07-2012, 04:02 PM
