    Apr 2005
    How to install a GF pressed in BB?
    I just bought back my old 1991 GF Supercaliber and needed to replace the sealed BB bearings. I reinstalled the new bearings, but now the BB is creaking. So, I just wanted to know the proper procedure for installing the GF pressed in BB.
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    Not much too it.
    Well the proper proceedure requires specialized tools but they aren't necessary.
    All you really need is a hammer and either some PVC pipe or some scrap wood.
    I would guess that the squeeking is comming form the spindle-bearing interface. I would knock the spindle out and put some grases on it.
    Apr 2005
    Quote Originally Posted by Shayne
    that's how i installed it. i did wonder about the spindle to bearing interface. it did not seem as snug as i thought it should be. i will disassemble and grease it.
    thanks
    Apr 2005
    It appears there is too much play between the new bearing and the spindle. i am going to take it back apart and use loctite to get the spindle and bearing to bond.
    Any other suggestions?
  1. Truvativ Gigapipe SL BB install on KM
    By steevo in forum 29er Bikes
    Last Post: 05-04-2007, 05:38 PM
  2. Lightweight, durable ISIS BB?
    By 1speed_Mike in forum Weight Weenies
    Last Post: 09-01-2004, 01:07 PM
  3. Trying to install crankset.....left crank arm rubbing BB
    By bayarearider in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-12-2004, 11:16 AM
  4. BB install question
    By jbf in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-04-2004, 07:10 AM
  5. World Class Ti BB install question
    By jbf in forum Weight Weenies
    Last Post: 04-27-2004, 08:10 AM
