Results 1 to 2 of 2
    Reputation: KevinGT's Avatar
    Dec 2012
    How the heck do you remove i-spec shifters?
    I want to move my shifter pods closer to my hands. They are currently set as far out as they will go and it looks like the i-spec mount gives me about a half inch of adjustability...if I can get to the screw!
    The screw that I need to loosen to move the pods is completely covered up by the brake master cylinder. I can remove the screw that connects the i-spec mount to the brake but the i-spec mount has some sort of hook that keeps it dangling from the brake lever. I've moved that thing around every which way and that and can't get it to unhook.
    I took the whole brake lever off the bike but that doesn't allow any better access to the screw OR allow me to unhook the shift pod connector.
    Any ideas??
    NEVER MIND: Figured it out. You have to remove the backing nut inside the brake lever clamp to allow the hook on the i-spec mount to come free. Pain in the butt, just to adjust the position of the shifters but it's all good now. While it is a pain, I do like the clean handlebar that i-spec creates.
    Reputation: PerthMTB's Avatar
    If you try and use a hex key from above on that nut then, yes, the brakes prevent access. However, that nut also has spanner flats on the side, so you can slip a 7mm spanner in between the shifter and brake to undo/tighten it.
  1. SLX i-spec shifters
    By Eric Madar in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-26-2013, 07:32 PM
  2. How the heck do you remove Cinelli Bar Tape?
    By JimInSF in forum General Discussion
    Last Post: 11-01-2012, 07:05 AM
  3. Shimano I-Spec shifters...
    By In-Yo-Grill in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-05-2012, 11:33 AM
  4. Replies: 2
    Last Post: 07-21-2011, 12:32 AM
  5. Can I Remove the Gear Indicator on SL-M760 Shifters?
    By outside! in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-30-2011, 02:57 PM
