Results 1 to 3 of 3
    Reputation: Quasi's Avatar
    How does one tighten the cone on a Shimano PDM-324 pedal?
    The cone is completely recessed. Any idea how one is supposed to tighten the locknut on the cone without being able to get a wrench on the cone to stop it from spinning? Is there a special thin-walled 13mm socket which can hold the cone while a 10mm socket is used to tighten the locknut?
    hhh
    hhh is offline
    It does exist!
    The exact tool you described does exist. Shimano Tool PD-73, pictured in this Park info sheet with some other usefull info.
    http://www.parktool.com/repair_help/FAQohSP.shtml
    Cheers.
    Quote Originally Posted by hhh
    Cheers.
    Moochas Gracias. Looks like the TL- PD-73 is the ticket.
    Edit:
    Actually, I need a TL-PD33 tool. I had to go to the Australian website for Shimano until I found the diagram which noted the tool on it:
    http://www.shimano.com.au/publish/co...M324-1972A.pdf
    Isn't Shimano just so very helpful. It would be a damn shame if they included that exploded diagram with the pedals in the box.
  1. New to the sport, need bike :)
    By iLLestOne in forum Bike and Frame discussion
    Last Post: 05-13-2005, 06:28 AM
  2. Component comparison Rockhopper vs Cinder Cone
    By Coops in forum Bike and Frame discussion
    Last Post: 02-21-2005, 02:28 PM
  3. 1FG hub play
    By jae in forum Cannondale
    Last Post: 04-23-2004, 09:00 PM
  4. Broken shimano pd959 pedal tension spring
    By mtb_junkie in forum General Discussion
    Last Post: 04-07-2004, 09:43 PM
  5. cone wrenche size for Shimano hubs
    By PBK in forum Tooltime
    Last Post: 02-17-2004, 01:44 PM
