Results 1 to 3 of 3
    Karma Vampire
    Reputation: 29Again's Avatar
    Mar 2005
    How to Distinguish between the PG-830 and PG-850 SRAM 8 spd Cassette
    I hope someone with actual parts can help me determine if I have PG-850 or a PG-830 cassette? I made a weak attempt to search this forum. I also checked out the SRAM website and the only difference I can glean from SRAM 2008 Tech Manual is the weight (280g vs. 320g respectively) and the material for the cogs (SAPH 440 Steel vs.Steel respectively). I have access to digital scale, but I doubt it is accurate enough given part and scale tolerances. As for material, no clue. Is there something stamped on the part itself or a distinguishing feature? Any information or comments are welcome.
    Thanks for your help and get out and grind some gear(s) today!
    I think that the cog screw cap is different colors for each type of cassette (silver vs. black)
    ... And I Am You,
    And What I See Is Me!
    Karma Vampire
    Mar 2005
    Follow up - weigh in
    I weighed the cassette and it came in at 274g. My lock nut is black, BTW. My guess it is a PG-850.
