Results 1 to 8 of 8
    Jun 2013
    Idea! how to convert to 2x8 drivetrain?
    My Cannondale is from 1996, fully rigid, non-disc brakes. I'm wanting to upgrade the crank to 165mm & the bottom bracket, but all I see online are 2x9 & 2x10 cranks. Are cranks really manufactured for certain gear systems like 9 speed & 10 speed? I thought any mtb crank can be used, regardless of your gear system. Also wanting to upgrade front & rear derailleurs. Current components below.
    shifters: XTR M910, 8 speed
    cassette: XT CS-M737, 8 speed, 11-28
    crank: Shimano Altus 170mm, chainrings 24/32/38
    chainrings are permanently factory attached to the crank)
    bottom bracket: Shimano BB-LP26
    bb shell width: 68mm English (square-tapered)
    chain: KMC X9SL Superlite 9 Speed Chain Ti Nitrate " x 11/128"
    front derailleur: Shimano AceraX top-swing, bottom-pull
    rear derailleur: Shimano AceraX
    wheels: Mavic Crossride UB 26" 2013
    frame size: 16 inch
    If I had a better triple chainring crank & removed the granny gear, would I need a bashguard?
    Would I need new front/rear derailleurs on a 2x8 drivetrain?
    When looking at online bike shops for cranks, it asks for BB Type:
    68MM / 73MM
    83MM
    External Cup
    PF30 83MM
    Standard
    No other types will work?
    Thank you very much
    Reputation: mitzikatzi's Avatar
    8 and 9 speed crank sets/rings are the same.
    The crank arms on a (Shimano) 10spd and 9 spd crank set are the same. 10spd rings are different to 9 spd rings. When 10spd rings are mounted on a crank set they are slightly closer together than 9 spd rings will be. Many on here claim a 10spd crankset/rings work fine on a 9spd system.
    10spd mixed with 9 spd there is a big "sticky" thread on it.
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    9spd shimano F&R derailleurs will work with your 8 speed shimano shifters.
    To fit a bash guard you normally mount it in the big ring position on the crankset.
    You can remove your square taper bottom bracket and fit a external type bottom bracket. You might need to get the frame "faced" at a LBS.
    A 68mm bottom bracket uses 3 spacers and a 73mm uses only 1. You will most likely have a 68mm BB
    A lot of information can be found at Sheldon Browns site.
    also have a read here
    Repair Help and Education
    Jun 2013
    Quote Originally Posted by mitzikatzi View Post
    Ahh i see@closer together
    Originally my bike was a 7 speed. Still have the stock Altus crank. I can really buy a 2x9 crank & all will be compatible?
    yes
    Jun 2013
    Tyvm mitzikatzi@9spd shimano F&R derailleurs will work with your 8 speed shimano shifters.
    And ty for the education. I'm saving that link in my favorites
    Jun 2013
    Idea!
    Understanding the new component standards can get really confusing. To help simplify things for me, will this crank work on my bike? I chose 165mm with 68/73mm BB
    Race Face Atlas Mountain Bike Crankset : Amazon.com : Sports & Outdoors
    JHB
    JHB is offline
    Jul 2015
    Hello Mitzikatzi
    I just refurbish a Bridgestone MB5 to drop bars and using Shimano Sora 3x8 sifters
    with A deore rear derailleur and I belive it a shimano road front derilleur . Front rings are 11/44 and 11/34 and running 26" wheels with 1.5 tires. I'm look to find a why to improve on shift gears. T.Y JB
  1. can I convert this DH drivetrain to 2x10?
    By mtb83201 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-08-2013, 07:42 PM
  2. SRAM Grip Shifters on Shimano Drivetrain & SRAM Drivetrain....
    By Dragon Of The East in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-24-2012, 07:47 PM
  3. Replies: 6
    Last Post: 10-05-2012, 11:12 AM
  4. Another drivetrain question- drivetrain noise
    By Streetdoctor in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-20-2012, 01:50 PM
  5. Drivetrain issues - please help - x post from Drivetrain
    By yohyat in forum Downhill - Freeride
    Last Post: 01-03-2011, 08:30 AM
