Results 1 to 11 of 11
    Reputation: TripleR's Avatar
    Dec 2005
    Horizontal dropouts and quick release skewers...
    I need a little help. Building up a GT peace 9er ss with horizontal dropouts...can I use a standard quick relase skewer or do I need a thru bolt specific hub. Yeah I know a quick answer for you guys and probably a simple one. Thanks
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    An XT level or better QR has worked well for me in the past.
    Stokeless Asshat
    Reputation: jeff's Avatar
    Post this over in the SS forum. You'll get some good advice over there.
    Zip ties? Not on my bike!
    Want:
    650B rims or wheel set. 80's vintage 32 or 36 x 135mm
    Reputation: Shalom's Avatar
    Nov 2008
    QR skewer should be fine. But, for the peace of mind, you might want to look at getting some nut tuggers (for example, the fantastic ones that ISAR make, which are compatible with both QR and bolt-on - Nut Tuggers!).
    Former Bike Wrench
    Tuggnut works well too
    Tuggnut | Parts | Surly Bikes
    On my Cross Check with horizontal drop outs, I use DT Swiss RWS skewers. Works great, no slippage, but then again it is geared.
    Reputation: IvanMTB's Avatar
    Hi,
    I have Inbred 29er slot dropout and without problem I'm using Hope QR. Chain tuggnut as well - On-One branded QR version.
    Cheers!
    I.
    LoMF syndrome...
    Reputation: Flat Ark's Avatar
    I use a Shimano XT skewer that I got off of Ebay for $10 and it works great. Had a Crank Bros. skewer on before and it was next to worthless at keeping my rear wheel in place.
    Reputation: Joe V's Avatar
    Jan 2011
    Have had this on my SS for a year, works great. Just make sure they are TIGHT.
    Internal cam skewers normally work fine with horizontal dropouts. Most shimano skewers will work.
    Dec 2005
    Thanks for all the reply! I did take a ride with the standard Dt Swiss skewers and found out....no go! I'll try the tugnuts as suggested. I put on a set of FSA Scatto skewers and see if they hold. Sounds like a little peace of mind with the tugnuts. Thanks again RRR
  1. Horizontal Dropouts, Quick Release, and Braking
    By slide mon in forum Singlespeed
    Last Post: 02-03-2011, 03:05 PM
  2. Horizontal dropouts and quick release
    By Vermont29er in forum Singlespeed
    Last Post: 11-01-2009, 09:05 AM
  3. Quick releases with horizontal (track) dropouts?
    By ingluis in forum Singlespeed
    Last Post: 10-30-2006, 07:00 AM
  4. Sliding Vertica Dropouts and Quick Release Skewers
    By aussie_yeti in forum Singlespeed
    Last Post: 10-27-2006, 09:32 AM
  5. Quick release scewer with horizontal drops?
    By singlespeed1 in forum Singlespeed
    Last Post: 03-31-2006, 01:44 PM
