Results 1 to 3 of 3
    Home made bash ring
    Can any one give me the out to out dimensions of a 36 and 38 tooth chain rings in inches please. I'm not forking 40 to 50 bucks for a bash.
    take 44/42 tooth large chainring. Get an electric jigsaw. Cut off all teeth. Take dremel to smooth it down a bit (not necessary) and you are done. Not the strongest, but it does work and you can probably use an old worn out ring that you or a friend has (cheap or free).
    Thanks, I have some 3/16 aluminum plate in the garage I think I'll use to make one.
