Results 1 to 6 of 6
    Mar 2006
    High Clamp vs. Low Clamp?
    Is there any difference other than looks in one over the other?
    On MTBR hiatus :(
    Quote Originally Posted by Downeaster
    You frame may be able to take only one of the two types, depending on construction / tupe layout. What frame?
    If you're asking more from a general curiousity standpoint, there are some dramatic differences. High clamp is a very simple, sturdy parallelogram design with two forged arms and four straight-through pivot points. Low band is constructed from stamped metal, has multiple rivet-type pivots, and unless something has changed in the last two generations, leaves the outside plate relatively unsupported compared to a high band. I found it very interesting to look over the two types side by side and see how differently they are constructed to accomplish a similar task.
    speedub.nate
    MTBR Hiatus UFN
    Mar 2006
    Nate,
    Thanks for the insight. I was just curious as to why the two different types. I am building up a 1999 Giant ATX 890 and am planning on using a SRAM high clamp.
    On MTBR hiatus :(
    I believe the ATX frames used oversized seat tubes that are deformed where they join the bottom bracket (which could interfere with a low clamp derailleur), so your choice is correct.
    speedub.nate
    MTBR Hiatus UFN
    Reputation: astro_nomenoff's Avatar
    I had a GT LTS that demanded a high clamp because of it's short, stubby false seat tube - I tried a low clamp but it wouldn't quite go low enough.
    I have a Yeti 575 now that demands a high clamp with bottom pull because the seat tube has a pivot point set into it that means a low clamp wouldn't fit.
    Reputation: oldskoolboarder's Avatar
    Does anyone know what type of clamp I'll need for my Ibis Szazbo?
