Results 1 to 2 of 2
    Help,XTR M 960 chainring
    I need to replace my middle ring on the latest version of XTR cranks. Can someone help me clarify 2 points. Given that the bolt pattern for the middle ring is 102mm I have to assume that there is no way that 104 4 bolt rings will ever work, correct?
    second question is does anyone make an aftermarket ring that will replace an XTR ( or new XT I suppose)
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    Check out Moonheadmachine.com
  1. Largest recommended middle chainring for a 22T chainring
    By jzt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-18-2005, 05:41 PM
  2. MOTD: Make sure your chainring bolts are tight
    By dubjay in forum Singlespeed
    Last Post: 12-13-2004, 05:24 PM
  3. Guarding chainrings from rocks without replacing large chainring
    By lougrandview in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-11-2004, 10:46 AM
  4. Snapped a chainring bolt last night
    By Birdman in forum Singlespeed
    Last Post: 07-01-2004, 11:15 AM
  5. Is your front chainring Ovalized?
    By fc in forum Singlespeed
    Last Post: 06-11-2004, 01:43 PM
