    My dog rules!!!
    Reputation: wldtrky101's Avatar
    Mar 2005
    Help, what do I need to adjust?
    I looked at the park tool site and see how to adjust the rear derailer but I don't know what to adjust. I don't want to go and mess with all the stuff since it works great 90% of the time. When ever I try to shift into either the biggest or smallest gears on the rear, the chain skips 2 gears. For instance, if I am in the 7th largest gear and shift once, it jumps up to 9. If I am in smallest gear and shift once, it does nothing, then I shift again and it jumps to the 3rd. Is this because the limits are off or do I have a bigger problem?
    pronounced may-duh
    Reputation: Maida7's Avatar
    Apr 2005
    If the limits were off then the chain would go too far and fall off the cogset one way or the other. I think you need to adjust the cable. Turn the barrel adjuster clockwise a quarter turn at a time and test between turns until it is fixed. Let us know how it works out. Good luck.
    All 26.5" all the time!
    Reputation: Zanetti's Avatar
    >>For instance, if I am in the 7th largest gear and shift once, it jumps up to 9.<<
    This would indicate the cable is too tight. (turn barrel adjuster clockwise)
    >>If I am in smallest gear and shift once, it does nothing, then I shift again and it jumps to the 3rd.<<
    This would indicate that the cable in not tight enough. (turn barrel adjuster counter-clockwise)
    As you can see, there'e more going on than just a cable adjustment.
    >>Is this because the limits are off or do I have a bigger problem?<<
    Sounds like you've got a dirty/sticky shift cable and housing or a bent derailleur hanger, or maybe both.
    My dog rules!!!
    Mar 2005
    I tried adjusting the tension on the inner wire, I think that fixed it. I was just doing it wrong before I posted. We will see when I get out for a ride tomorrow.
