Help - Shimano XT or Sram X.9??
I have an '04 GT Avalanche with Deore Components and I am looking to upgrade to either Shimano XT rd with Shimano XT 9 speed rapidfire shifters or to SRAM X.9 rd with X.9 trigger shifters. I would like to hear some experiences from you guys (and gals) so I can make a decision. When I do upgrade, do I need to upgrade the cassette and chain also?
THANKS!!!!
Chrome Toaster
They are both pretty much equivalents and very good but you'll get wildy ranging opinions depending on what each person prefers. You can try searching the forums as there are literally dozens of threads (often very heated ones) on this subject.
The devil is an angel too
I found them pretty much equivalent also, when it comes to performance. The X9 seems to me easier to install and adjust, also stays tuned longer. The XT is a solid value when it comes to durability, though. I like the SRAM triggers better, but that's personal, performance wise I would say they are the same as Shimano's. Some people complain about the low feedback from the springs in the SRAM's that can lead to overshifting. I can say that it is true that you can hardly feel them click, so far not a problem to me (note I am on X7's not X9's) I went with SRAM because I wanted to try something different from shimano, and so far I am not disapointed. But I can't speak badly of the XT. At least not too badly.
If you are tight with money, and your bike is 9spd already you should consider upgrading just the rd to XT, and save some dough, and if you are running a deore fd, you may want to spend an extra $30 and get a SRAM Xgen or shimano XT. It will probably improve the front shifting a lot. If you stay with your old shifters, replace the cables anyway, they don't cost a lot and rusty cables can cause a lot of headaches.
Finally, if your cassette/chain are old, you should serioulsy consider replacing them. You are never going to get good shifting with an stretched chain, and an stretched chain will damage your cassette. And a worn out cassette will damage your chain.
Get your freak on!
110% agree and second everything that is said above...
By zaskar in forum Drivetrain - shifters, derailleurs, cranks
Last Post: 04-21-2005, 08:07 AM
By bullit71 in forum Downhill - Freeride
Last Post: 03-08-2005, 10:25 PM
By Slowjett in forum Drivetrain - shifters, derailleurs, cranks
Last Post: 09-20-2004, 05:04 AM
By Manny Omega in forum SRAM
Last Post: 04-15-2004, 01:39 AM
- You may not post replies
- You may not edit your posts
Forum Rules
