Results 1 to 6 of 6
    Feb 2006
    Help removing an xtr cassette...
    I took the lock ring off and the cassette still will not come off. Is there another step with this cassette? It is on a king hub.
    Rob
    meh....
    Reputation: Monte's Avatar
    Quote Originally Posted by RobPaterson
    Rob
    lightly tap the smallest cogs with a plastic hammer if you have one. they're dug into the freehub body a little. use a beater screwdriver handle or something if you don't have a plastic hammer. or use a steel hammer gently.
    ups and downs
    and more specifically, tap them lightly in the reverse direction from drive pressure. You can also use a piece of wood as a striking surface for the hammer.
    someone correct me if i'm wrong but I'm assuming you are using a chain-whip in addition to the cassette remover....
    meh....
    Quote Originally Posted by osmarandsara
    The OP said "I took the lock ring off and the cassette still will not come off." Sounds like he's past that point. The small cogs are just dug into the freehub body most likely.
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    + whatever everyone else said.......the cogs have dug into the freehub body. Do whatever you need to do to dislodge them. Banging them in the opposite direction is a good idea. Then pull.
