Results 1 to 5 of 5
    rack admirer
    Reputation: Mr Magoo's Avatar
    Help removing race face crank arm 1x11 to swap chainrings
    I wanted to experiment/replace the 32 chainring with a 28 since I am headed to some steep climbs this weekend. I am having trouble removing the (driveside) crank bolt on my 2016 5010 C S. Its a Race Face Crank and I only see one bolt to remove the crank arm. Is this left or right thread? I tried significant force in either direction and wanted to be sure of the correct direction before applying more force. Is there something other that force that I should be considering here?
    Thanks for sharing any knowledge, experience or opinion with me.
    Mike
    MCM # 57
    since 4/10/2009
    Reputation: Harold's Avatar
    This is the install guide for the Race Face Aeffect crank on your bike. That crank bolt is supposed to be torqued to 61Nm, which is more than just significant force. You're really going to need to wail on that bolt to break it loose.
    http://www.raceface.com/media/B10187...lation-Web.pdf
    rack admirer
    harold,
    Thank you. this is gold.
    happy riding
    MCM # 57
    rack admirer
    Help.
    The instructions say to gently tap the arm on to the spline with a hammer. They are now together fused. Can you suggest a way to split them off the spline?
    Thanks a milion
    MCM # 57
    spray liquid wrench let sit over night. hammer, uhh i mean tap. get long cheater bar attached to end of ratchet. need someone to provide resistance, like bracing crank arms or frame.
    Sent with Tapatalk
  1. Replies: 8
    Last Post: 12-29-2016, 12:06 AM
  2. Question on removing Race Face Deus XC Crank?
    By guht in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-02-2016, 08:54 AM
  3. XT, Race Face, or Deore crank for 1x11
    By Gherrmann19 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-10-2016, 07:10 AM
  4. Running both a Race Face bashguard light and a Race Face NW on Shimano 2x crank?
    By SB666 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-12-2015, 11:02 AM
  5. Race Face Turbine to White Industries Eno Crank Swap
    By Hemi01 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-16-2012, 12:28 PM
