Results 1 to 3 of 3
    Knolliac
    Reputation: EastBay_Slim's Avatar
    Help e.thirteen supercharger install
    I need some assistance. I just purchased an e.thirteen supercharger size 104, 4 bolt, for 44 tooth chain ring so I can keep all three rings on my crankset, FSA Afterburner. For the life of me I can't seem to figure the installation out as there is insufficient room between the crank arm and the outer ring. Are there components compatible?
    neutiquam erro
    Reputation: Chris130's Avatar
    Mar 2005
    Superchargers replace the big ring (for use on a 2x9 or 1x9 drivetrain).
    Cheers, Chris
    Edit: Not certain if e13 makes a bash for that setup with all 3 rings, but other designs are out there...
    Now is the time on Sprockets when we hammer.
    '05 Blur Classic (1x9) || '06 SIR9 (SS) || '06 Brompton P6L
    Meh.
    Reputation: XSL_WiLL's Avatar
    It is supposed to replace the big ring. Your only option is to grind off some of the bashguard where it is hitting (depends on how much you need to take off). We've managed to put one on without modifying it before (other than spacing the bashguard away from the chainring). I forget what crankset it was. I remember it was a Jamis Dakar.
