Results 1 to 7 of 7
    Reputation: airic81's Avatar
    Caution;  Merge;  Workers Ahead! HELP! Clicking noise on my Redline Monocog 29er SS
    HELP!!!
    This stupid clicking noise is driving me crazy. So i have an 08 Redline Monocog SS 29er with this stupid clicking noise near Bottom bracket. The noise occurs after ever 3-4 full revolutions. I looked on the forums and replaced the following items in order:
    1. Replaced the pedals and greased.
    - Clicking still there
    2. Cleaned and regreased the OEM bottom bracket and tightened crank.
    -Clicking still there
    3. Replaced the chain to KMC Z410
    4. Replaced Bottom Bracket to Shimano BB-UN55
    -Effing Clicking Still there!@!!!!
    Now do you think it has to do with the alignment with the chain or the slack of the chain?
    Any help is appreciated.....
    I4NI
    Reputation: S_Trek's Avatar
    May 2010
    Under heavy load or anythime
    There....Are... Four...Lights!
    Quote Originally Posted by S_Trek View Post
    clicking happens anytime
    Hmmm the clicking is still there. I added more slack to the chain and thr clicking doesnt happen as often now. This is aggrevating. I also tightened the chainring bolts
    Sent from my HTC Sensation 4G using Tapatalk 2
    Reputation: jimbowho's Avatar
    Dec 2009
    Maybe your hub is doing something funny ???
    Oct 2012
    My 2007 monocog does this to me. I've taken all the measures to fix it, I even have a completely different drivetrain in there. My conclusion is that with it being an aluminum frame that isn't very rigid like a road bike, it's bottom bracket flex is a bit more extreme, so when you stand on one pedal (and are unable to pull up on the upstroke of the other if you're using platforms) then the bottom bracket sways a fair bit to the side. This will cause the teeth of the front chain ring to bite the edge of the chain as it comes close to dropping.
    Quote Originally Posted by sean... View Post
    Oh ok thanks. And yes ive stood on the pedals and also noticed alot of flex. I gues ill end the quest here and just save for a new frame over the winter.
Hot Deals
Contests
Latest Mountain Bike Articles
