Results 1 to 2 of 2
    Help on Bottom Bracket
    I have LX HollowTech cranks that are a few years old, I think i may need a new BB because i feel a kind of "skip" when pushing on the pedal/s on my 5spot, i have checked the pivots, they are not loose-not the pedals either - don't think it is the cassette either.. so the only other thing that i believe it could be is the BB, since that is exactly were i feel it coming from. Soooo my question is.. can I use a XT BB, which is a ES-70, i believe the one i have is a ES-71 - but i am not sure if i can ONLY use a ES-71on the LX cranks, i am not sure what the difference is - they look the same, will the ES-70 change the chain line?
    On MTBR hiatus :(
    If it's the LX 571 (previous generation; straight arms) you can use any ES series bottom bracket in a 113mm or 118mm spindle length.
    If it's an LX 572 (current generation; "fat" arms) you're stuck using an ES-51 in 121mm or 126mm spindle lengths only.
  1. bottom bracket type??
    By Styles in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-06-2004, 10:06 AM
  2. @#$%^&* Shimano bottom bracket mounted derailler
    By old_dude in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-02-2004, 10:04 AM
  3. Please help! Broken bottom bracket lock ring.
    By Bart in forum General Discussion
    Last Post: 05-15-2004, 01:09 PM
  4. brand new bottom bracket, broken?
    By kenaran in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-12-2004, 10:47 AM
  5. Help with bottom bracket
    By DoothaBartman in forum General Discussion
    Last Post: 04-10-2004, 02:44 PM
