Results 1 to 8 of 8
    Reputation: eric_syd's Avatar
    Help: BB30 crankset with std BB shell ?
    Sorry if question has already been asked.
    I could not find it.
    Can you use a crankset designed for a BB30 Bottom Bracket (e.g. FSA afterburner) with a standard external bearing Bottom bracket in a standard frame shell or is the spindle diameter bigger ?
    can't be done
    S-Works Venge
    S-Works Allez
    S-Works Crux Disc
    Stumpjumper Expert EVO HT 29er
    Crux - Team Stumpjumper
    Former Bike Wrench
    Standard two piece crankset spindle is 24mm (or 24/22mm for SRAM)...BB30 is 30mm
    Find an E13/The Hive BB30 external BB - goes in where a normal external BB would, and allows 30mm spindle cranks. I've never done this myself, but I can't see why it won't work.
    Quote Originally Posted by monolith View Post
    Thanks to all. Probably too hard. I understand why BB30 cranksets don't find buyers even for cheap on eBay Australia....
    eBay Australia: Buy new & used fashion, electronics & home d
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    The Hive bottom bracket cups will do the trick.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by AZ.MTNS View Post
    The spindle will fit in the bearing cups but is the BB width correct? I do not know.
    mtbtires.com
    Manager
    Anyone actually ran the BB30 crank with the hive BB cups? Were they the AM/DH cups or the XC cups?
  1. BB30 crankset w/ PF30 BB?
    By ghughes.hesinc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-09-2013, 07:36 AM
  2. Shimano cranks on BB30 shell
    By fredy_signer in forum Cannondale
    Last Post: 05-24-2012, 12:59 AM
  3. Replies: 6
    Last Post: 03-15-2011, 01:58 PM
  4. 2011 S Works BB30 Shell?
    By JMCCRNA in forum 29er Bikes
    Last Post: 09-10-2010, 10:05 AM
  5. Pivot 429 options for Cranksets??? bb30/100mm shell
    By metelhead in forum Pivot Cycles
    Last Post: 01-04-2010, 03:09 PM
