Results 1 to 15 of 15
Thread: Grip shift
    Jan 2013
    Grip shift
    Why go to grip shift?
    JDM
    JDM is online now
    Reputation: JDM's Avatar
    cheaper, lighter and still changes the gears well enough.
    Personal preference of the mechanics. Same reason I prefer Shimano to SRAM.
    Give it a crank
    Reputation: Mtn-Rider's Avatar
    May 2010
    It takes a single action to switch to any gear, from any other gear.
    Jan 2013
    Does shimano make a good grip shift?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Enduro14 View Post
    GripShift is a trademark of SRAM.
    No, Shimano does not currently make a twist shifter.
    SRAM does still offer 8 -and 9-speed twist shifters for Shimano RDs
    mtbtires.com
    new name, old member
    Reputation: Bike Whisperer's Avatar
    Mico-indexed front shifter allows fine tuning of front derailleur
    Single and loving it (single speed bike that is)
    http://mtnbiker72.blogspot.com/
    http://www.ccfa.org/
    Jan 2013
    Are the sram grip shifters good?
    Yes. The positives have been mentioned. The main negative is the space requirements on the bar.
    I just measured my bars for reference.
    X0 9sp Gripshift - Ergon short grip - Magura MT4 lever - crammed together = 7 3/8"
    X9 Trigger/brake combo - SRAM Foam grips - some space between = 6 3/4"
    Dec 2012
    SRAM XO 210 grip shifters
    I just installed a set of 2x10 Sram xo grip shift and they're great. Smooth and precise shifting and you can downshift thru all of your gears in one swoop. I thought it would take a bit to get used to them but after one ride, I don't even notice that they are on the bike. I have them on 680mm bars and have more than enough room. I highly recommend!
    I've also bought SRAM X0 grip shifters, still haven't tried them though...
    Reputation: Eville140's Avatar
    They work well with thick gloves on also.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
    Oct 2012
    I have the 2x10 XO set on my Trance X. I've always preferred
    grip shift. When I got my new Trance about 2 months ago
    I had a right thumb injury from a motorcycle crash. It was
    real painful with the stock shifters so I made the switch.
    No levers to get in the way either.
Hot Deals
Contests
Latest Mountain Bike Articles
