Results 1 to 10 of 10
Thread: Gravely Feel?
    Reputation: targnik's Avatar
    Jan 2014
    Gravely Feel?
    So, I noticed this yesterday during an event... local = drivetrain
    Course was slop - so I figured it was just some 5h1t caught up from the ensuing mud bath.
    Gave bike a thorough clean & relube...
    Took bike out today with my two youngest and noticed it again on any incline that required a bit of load.
    Upon closer inspection on turning cranks I can definitely feel the dreaded gravel.
    Question is: can I (lbs), just change out the bearings?
    Or, would it be prudent to get a whole, new bottom bracket?
    T.I.A
    Sent from my kltedv using Tapatalk
    Last edited by targnik; 10-15-2016 at 04:29 PM. Reason: Dam auto correct!! Gravelly not Gravely...
    "Mountain biking: the under-rated and drug-free antidepressant"
    Reputation: Bahamut2119's Avatar
    Apr 2016
    Depends on what bb type you use for instance I use shimano 73mm/14mm bsa bottom brackets if one wears out I just replace it there only 20ish at the lower end.
    Jan 2014
    Quote Originally Posted by Bahamut2119 View Post
    Shimano Pressfit 92...
    Bearings? Or, get new unit?
    T.I.A
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by targnik View Post
    T.I.A
    buy a new one. I hate the plastic shimano PF cups. they're not even worth replacing the bearings in. I'd buy something better than shimano, fwiw.
    Apr 2016
    I agree those can be more than cheep enough to toss in the trash I just happen to have looked them up for pricing a few hours ago I got a bunch of money coming and tempted to build a new bike.
    Nutrailer
    Reputation: JackWare's Avatar
    Aug 2016
    Quote Originally Posted by Harold View Post
    I think the use of a capital letter for the beginning of a sentence and the brand name Shimano is warranted here
    Bearings rough? You need a new bike!
    j/k
    First, did you spin the crank without the chain on? That'll help eliminate other causes before tearing things apart. If so, then...
    New bottom brackets are basically designed to be use and throw away, but really they're not that hard to deal with in most cases.
    I'm not sure on all bottom brackets, but I just rebuilt/re-lubed an old GXP for the 2nd time recently. Good as new. The one caveat is the seals are not the most rugged, so this isn't for everybody. Gentle is good.
    First half of this vid as an example, but each is a little different. Once opened up I like to soak in degreaser and spray out a couple times. Make sure they spin smooth at this point. Then let dry completely, pack with waterproof grease and reassemble.
    Takes a little time and effort, but saves $15-20 each time. I actually have a spare so one is ready to go in and I can rebuild later. Getting a new one and experimenting on this one might be the way to go if you're up for it. I'm sure the LBS will give you the old one if you ask.
    *edit: just noticed Harold's comment that the plastic ones are not so good, so might not be worth the trouble but going to leave this for future reference.
    since 4/10/2009
    Quote Originally Posted by JackWare View Post
    Dafuq?
    Dafuq?
    well u know, cuz gramer AND Stuff. lol
    Sum people are never hapy
    Jan 2014
    Received advice from bike manufacturer...
    Was advised to go Shimano BB94 ^^
    Got one off eBay for not many $$
    LBS says it won't last... but, the BB92 it's replacing has lasted almost 2 years.
    Hoping for more from a later product.
  1. Norcal gravely grinder fans,, try Idaho?
    By zon in forum California - Norcal
    Last Post: 06-03-2016, 04:34 PM
  2. How gravely... is too gravely?
    By targnik in forum 29er Components
    Last Post: 12-28-2015, 04:17 AM
  3. I feel the need....I feel the need for speed.
    By DIRTJUNKIE in forum Off Camber (off topic)
    Last Post: 12-12-2015, 01:19 PM
  4. Oh Man, I feel sorry
    By Mr5150 in forum General Discussion
    Last Post: 04-25-2015, 03:07 PM
  5. New rear tire for rocky/gravely trail
    By arctic slalom in forum Wheels and Tires
    Last Post: 07-24-2013, 08:16 PM
