Results 1 to 2 of 2
    Getting back into it...
    Reputation: ryanc44's Avatar
    granny ring/mid ring size difference
    What is the max difference you can run between your granny and the mid ring on a 2-ring setup? I currently have a 22/32 setup with a Shimano M760 Derailleur. I want to look into getting a larger mid-ring. I thought a 38 would be perfect, but someone at the good ol' LBS said you shouldn't/can't run larger than a 15T difference between rings, hence a 38 would be too big. Just wondering if this is true. The specs on the M760 give a "Front Chainwheel tooth difference" (22T) and a "minimum difference between the top and intermediate" (12T), but no info about the granny and mid ring difference capabilities/restrictions...
    would you believe a 24/42/52 crankset?
    Go to Icyclesusa.com and take a look at this Ritchey road/touring crankset. I couldn't believe the jump between the granny and middle ring that it has.
    Otherwise, the most teeth difference I have seen is 12T.
    glenk
  1. Welcome, here's your 29er FAQ thread!
    By ncj01 in forum 29er Bikes
    Last Post: 06-20-2012, 01:56 PM
  2. Replies: 8
    Last Post: 08-27-2004, 10:15 PM
  3. Replies: 2
    Last Post: 07-21-2004, 09:53 AM
  4. What size single ring for hard trail riding?
    By titusguy in forum Downhill - Freeride
    Last Post: 05-24-2004, 08:06 AM
  5. correct size bash ring?
    By Redmon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-11-2004, 08:57 PM
