Gore RideOn or NOKON Cables
about to put new cables on the Mach 5, any thoughts on Gore RideOn vs. the NOKON?
http://www.competitivecyclist.com/mo...bles.1556.html
http://www.competitivecyclist.com/mo...45.2351.0.html
any thoughts would be much appreciated. i am inclined to go with the Gore cables simply because i have used them in the past...
 Originally Posted by scoutcat
As much as I like Nokon housing, I have had issues with ghost shifting on my suspension bike.
Switched to standard bulk full length SIS housing with a teflon coated cable and it works fine. No need to spend the $$ on Gore.
mtbtires.com
Honestly, I've used both, functionally can't tell a difference. I have since gone to the flack jackets and have the same results at a lower cost. If you're going purely for function, I see no reason to get more than jackets, if you want a little bling + function, get the Nokons.
Jagwire L3 here. No need to spend more money on housing if you ask me.
I have the Gore stuff right now and I'm not very pleased with its performance especially for the price. I wouldn't recommend Gore. I've have good luck with Jagwire, Shimano, and SRAM cable kits though.
- You may not post replies
- You may not edit your posts
Forum Rules
