Results 1 to 16 of 16
    Site Owner
    Reputation: brumbrum's Avatar
    good smooth clicking 6 or 7 speed twist shift
    Can anyone recommend a make n model of twist shift they may have tried and can recommend please? preferably 6 or 7 speed.
    Former Bike Wrench
    Sram Mrx
    Never trust a fart
    Reputation: frdfandc's Avatar
    As mtnbiker72 said. The Sram MRX for Shimano rear derailleurs.
    But you can also add to the mix the following
    Shimano Revoshift (Shimano Rear derailleurs) or the Sram 3.0 ESP if running a Sram rear derailleur.
    Site Owner
    ok thanks. i just bought a Sram 3.0 (not comp) and it was the worst chinese cheap plastic rubbish that i ever had the displeasure to lose my temper with. Infact it broke before i even got it on the handle bar. i ope the MRX has a smoother gear change and feel?
    Cheers
    Site Owner
    the revoshift looks better made tbh
    i have an Shimano XTR derailer btw
    Former Bike Wrench
    Quote Originally Posted by brumbrum
    If your running 7 speed, you can use a 8 speed shifter (just lock out the last shift)...this makes the MUCH nicer SRAM Attack shifter available to you
    Site Owner
    atm i'm running 6 speed, is it possible to lock out more than shift?
    Former Bike Wrench
    6 speed is different spacing so no, it will not work. 7 and 8 speed spacing are almost identical so that is why you can use a 8 speed shifter on a 7 speed cassette.
    Site Owner
    arh, ok. i'm trying to get hold of a 7 speed freewheel at present as a replacement for my 6 speed, but only if i could get an 11 cog sprocket. but it seems i cannot as freewheels do not go down to this size. I have no room for an 8 speed
    Site Owner
    Quote Originally Posted by mtnbiker72
    Do you think this 7 speed freewheel would work with the 8 speed SRAM Attack shifter?......
    http://cgi.ebay.com.sg/DNP-Epoch-7-S...item35ae240654
    Andrew
    Former Bike Wrench
    Andrew
    Well how about that...it should. DNP is a Chinese company that makes the Nashbar house brand cassettes. They don't shift as smooth as Shimano but they work OK.
    Site Owner
    thanks, you've been helpful. when you say 'lock out the last gear shift', how is this done?
    Former Bike Wrench
    Using the "H" limit screw to keep the shifter from shifting into the "lowest" gear. This makes the numbers slightly off (2-8 will be used) but otherwise works perfect.
    Site Owner
    Thanks again. i will order a sram attack and go from there. I have ordered to 11cog freewheel too
    Reputation: shiggy's Avatar
    Dec 1998
    But do you have a freewheel or cassette hub. They are not the same.
    mtbtires.com
    Site Owner
    Quote Originally Posted by shiggy
    thanks for your concern, it's a freewheel, that is why i've found it difficult finding an 11 cog set, they are pretty hard to find
