Results 1 to 2 of 2
    Off the saddle
    Reputation: jizzim's Avatar
    Going 2x9 to 1x9..need help on front (26er)
    I've been running a 27/40 setup with a 11-34 but find that the 40 front ring is a bit tough on my legs. I can pedal through my home turf but I would like it to be a bit easier as I am starting to build up strength again after a LONG hiatus. The 40 is doable but not comfortable. By going to a 1x9 now it gives me a reason to try something a bit more leg friendly.
    Keeping the same cassette, what would be more "all around" for the front chainring? I know it depends on your health and strength but I would like something most anyone who uses the bike would be comfortable with. The climbs here aren't crazy but there are a few. Fire roads? We have stretches depending on the location.
    Right now I'm thinking about a 34t front. This is for a 26er.
    May 2012
    Re: Going 2x9 to 1x9..need help on front (26er)
    To estimate what you will be comfortable with, test with your correct setup. 40/13 is about the same ratio as 34/11, so if you're comfortable with that, try a 34.
    On the other side, 27/26 is about the same as 34/34, so also in the climbing range you would be good. Main difference would be the larger steps when shifting through the gears.
    Still: it is personal preference!
  1. Replies: 8
    Last Post: 09-22-2011, 04:02 PM
  2. Moots YBB 650b front 26er rear? Thoughts..
    By Magnum Ti in forum 27.5
    Last Post: 08-25-2011, 02:27 PM
  3. comfort: 29er rigid vs 26er w/ front suspension
    By brettsportler in forum 29er Bikes
    Last Post: 07-21-2011, 05:30 AM
  4. Fattest 26er Front Tire To Fit Between V-Brakes
    By Toff in forum Wheels and Tires
    Last Post: 07-20-2011, 10:06 PM
  5. Fat front on inbred 26er?
    By vemeno in forum Fat bikes
    Last Post: 04-28-2011, 04:47 PM
