Results 1 to 18 of 18
    Going 1x10, not sure what all I need
    As the title says I want to try going 1x10 on my SC Nickel. Currently using a X0 38/26 crank with a 10spd X9 rear derailleur. What do I need to buy to make this crank work without a bash guard as well as what chain guide would be recommended?
    Reputation: Brig's Avatar
    Pick a chain guide based on what you ride and where you want to mount it. Seat tube, ISCG, or BB mount. pick a chainring size and buy a single speed chainring. Pull off the FD, shifter, cable and chainrings.
    Lots of info here, you should do a search.
    GG Smash
    I think I will try a WolfTooth 30th chainring but am having a hard time finding a good chain guide. Most say they work for a 32t-42t not finding much luck for a 30t.
    What kind of mount? ISCG? BB? Seat tube?
    Do you want to run a bash? Integrated bash? Lower and upper, or just upper guide....
    Lots of questions.
    I just bought the RaceFace Narrow Wide chainring and love it....they make a 30t as well.
    MRP has the 1x chainguide and AMG BB mount that fits 28-32t. I like the AMG because it has an integrated bash.
    GG Smash
    MTBR Member
    Reputation: ncfisherman's Avatar
    Quote Originally Posted by Brig View Post
    I'm running these too and they work.
    Do you really need a full chainguide? You could opt for a type 2 SRAM derailleur instead of the chainguide.
    Reputation: brankulo's Avatar
    Aug 2005
    no need for chain guide, get narrow wide from raceface (about 1/2 price of wolftooth, works same) and clutch rear der.
    Depends on if he wants to replace his derailleur. I had iscg tabs and a perfectly fine x9 rd. didn't see the benefit of changing.
    GG Smash
    Well I got a MRP Bling Ring, going to give that a shot hopefully next week and go from there.
    I went 1x10 earlier this year with a 30T front ring and X9 Type 2 rear derailleur. Cassette is 11x36. Unfortunately the chain will fall off the ring occasionally. Usually it's when going high speed with the chain mid-cassette or lower (smaller cogs).
    So I am looking for a lite chain guide to prevent this. What prevents a chain guide that mounts on the seat tube to accomodate a 30t ring as they all specify that it starts at 32t?
    I presume that if you adjust the height on the seat tube it should work with 30t. Am I missing something?
    Thanks,
    S.
    Reputation: Tarekith's Avatar
    Mar 2005
    Have you checked out the Bionicon guide?
    Tarekith.com
    '17 Specialized Enduro Elite 29
    Quote Originally Posted by Tarekith View Post
    I did. I am unsure how much it would help considering that the guide itself is made for 2x10 and 3x10 set-up so the guide itself will swing left to right to accomodate the different chainline from the different chainring.
    I presume it will still swing in the rough. But it may provide just enough resistance to prevent the chain from falling off.
    I have to find if somebody else has tried it for the same set-up I have.
    Aug 2013
    Quote Originally Posted by Evil Sylvain View Post
    Have you tried removing a few links to tighten up the chain line. If you're using a "narrow-wide" ring like RaceFace or Wolftooth with proper chain setup, you shouldn't be dropping your chain or need a chain guide. I have an X9 derailleur with 32t WT ring and haven't lost my chain even on drops and tech downhill.
    Quote Originally Posted by kickhorse View Post
    I did keep the same chain length I had with the 2x10 set-up. After a couple of rides I did not have any issue but then the chain fell off in my 3rd or 4th ride. I will try removing a pair of chain links. Thanks for the advice.
    I will also be installing a Zee RD with XT shifters after reading that the X9 Type2 should not work smoothly with a 11-36 cassette. Max is theoretically 11-34 according to the Sram compatibility table.
    BTW, I am using a MRP Bling Ring and the bike is Devinci Dixon with Split Pivot.
    MTBR Member
    The MRP Blingring is a SS ring, but it's not going to hold the chain like the Race Face Narrow/Wide or Wolftooth chainrings. The RF and WT rings have narrow and wide teeth which fit the profile of inner and outer chainlinks.
    Jul 2013
    Quote Originally Posted by brankulo View Post
    For those running a non-direct mount single-ring: may I ask what spider arm you're using?
    I converted my x9 2x10 into 1x10 with a MRP Bling Ring and sram type 2 derail, and didn't realize it wasn't a wide/narrow profile ring. I've been using a paul chain keeper and it's ok once I got the chainline setup right; I'll only drop a chain in the worst of rooted terrain.
    But now I'm considering going with a Race Face/Wolftooth/FSA wide/narrow ring and I don't know if I could use my old x9 spider or if I should buy something else? Thanks!
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Why not just go for the Wolftooth spider less Ring, It will bolt right up to your X9 crank.
    Or if you don't want to go that way, If your spider is for 38-24 or bigger you are to limited with that spider so take a look at North shore billet.
    Quote Originally Posted by Armada_23 View Post
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    Jul 2013
    Quote Originally Posted by muzzanic View Post
    Thanks for your reply, Muzzanic.
    I'm looking at the 104 bcd setup because I can't find a direct mount 38t ring. I do a lot of dirt-road racing on my mtb so I need that extra top end speed.
    My x9 spider arm was a 42/28 so it would appear that I'll have to pick up something like the north shore billet spider. Thanks again!
    Quote Originally Posted by ncfisherman View Post
    Thanks for the information. I had not realized the difference.
    Last evening I have changed the rear derailleur for a Zee and removed a couple of links from the chain. I'll test that set-up. If that still does not work I'll probably get one of the rings you suggested.
    Cheers,
    S
  1. RIP 9 1x10
    By jasondobrinick in forum Niner Bikes
    Last Post: 10-26-2013, 01:18 PM
  2. XTR 1x10 or XX1?
    By RockyJunky in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-27-2013, 11:24 PM
  3. 1X9 or 1X10?
    By jesse101 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-22-2012, 09:36 PM
  4. 3x10 -> 1x10 or 2x10 -> 1x10...which is better?
    By savechief in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-07-2012, 06:13 PM
  5. 1x10 set ups
    By GatorB in forum Gary Fisher
    Last Post: 01-09-2012, 04:16 PM
