Results 1 to 11 of 11
Thread: ghost shifting
    ghost shifting
    will chain lube fix ghost shifting and all around noisiness?
    Vaginatarian
    Quote Originally Posted by airrick
    no it wont
    ok thanks, in that case what will?
    Reputation: shiggy's Avatar
    Dec 1998
    Depends on the cause. Happens for different reasons on different bikes. It may not even be ghost shifting.
    mtbtires.com
    Vaginatarian
    easiest & cheapest fix would be adjusting the deraillier.
    when you say noise what do you mean? chain rubbing? squeeks? brakes rubbing?
    chain rubbing is prob. deraillier adjustment
    look at the chainrings and cassette, if the teeth are pointed, hook shaped or bent you prob. need new ones.
    measure your chain from pin to pin 1' if its off more than 1/16" get a new one
    check your deraillier hangar, if its bent it can be bent back or replaced
    that should do it
    Reputation: Henry Chinaski's Avatar
    Feb 2006
    Quote Originally Posted by dan0
    that should do it
    Don't forget to inspect/clean/lube cables and housing, and replace if necessary...
    Reputation: mjsca07's Avatar
    Dec 2005
    I've had this recently. From my research it's mainly due to cable tension. Adjust your cable on your rear derailleur. My understanding is when you put a load on your pedals there's a bit of tension put on the frame and cables get stretched a bit. This could cause ghost shifting. As with the other posts, it could be other reasons as well but start with the cable tension. To appy tension, adjust the knob on your trigger out (counterclockwise), and to loosen it you'd turn it inward (clockwise). I played with mine untill it shifted well and ghost shifts went away.
    ol'guy who says hi &waves
    Reputation: fred-da-trog's Avatar
    Oct 2003
    What they said plus............
    this little gem has eliminated all my shifting problems. A bit pricey but worth it.
    http://www.parktool.com/products/det...=48&item=DAG-1
    Do a search for best price.
    I may not have the best of everything, but I have the best everything that matters.
    for "ghost shifting" first check your cable routing and housing. I took my new FS bike out to the trail last weekend and it ghost shifted horribly. Every time the suspension compressed it would shift gears. Upon examination it turns out the section of rear derailleur cable housing between the front and rear triangle was too short and causing tension on the cable when the suspension moved. I replaced the housing with a longer piece and now it shifts perfect on the trail!!! Then make sure the derailleur is adjusted correctly.
    Mar 2006
    I had a friend stop by with some ghost shifting issues, and was able to solve the problem by tightening the chainring bolts, and making sure the back wheel was aligned properly.
    Paste eater
    Reputation: Jwind's Avatar
    Mar 2006
    Quote Originally Posted by mjsca07
    If it was shifting properly recently, than this will most likely fix your problem. Just remember, little adjustments until you get it.
